which one is safer?? wet nos kit or dry zex kit??
Old 12-25-2001, 06:38 AM
New User
v-tec crx's Avatar
Default which one is safer?? wet nos kit or dry zex kit??
which one is a safer kit?? thanks
Old 12-25-2001, 06:43 AM
DragII's Avatar
Default Re: which one is safer?? wet nos kit or dry zex kit?? (v-tec crx)
Dry Zex, IMO
w/ no more than a 50shot should be quite safe.
Old 12-25-2001, 08:37 AM
KawiGreenVTEC's Avatar
Default Re: which one is safer?? wet nos kit or dry zex kit?? (DragII)
I would say dry ZEX only for one reason, you are limited to how big of a shot you can use, but any N2O setup is safe as long as you adjust your fuel delivery to match your N20 delivery and adjust your spark accordingly as well.
Old 12-25-2001, 08:55 AM
94HybridEX's Avatar
Default Re: which one is safer?? wet nos kit or dry zex kit?? (KawiGreenVTEC)
What is difference between wet and dry?
Old 12-25-2001, 09:26 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: which one is safer?? wet nos kit or dry zex kit?? (94HybridEx)
ZEX kit, for dry shot.
Old 12-25-2001, 10:41 AM
WykidEH's Avatar
As long as you keep it reasonable, NOS is the ****! I've used it for years w/no probs. . . . .
Old 12-25-2001, 11:52 AM
Dry shot inject N2O only through the nozzle, fuel pressure may or may not be increased at the regulator depending on the system you are using.
Wet shot injects N2O and extra fuel through the same nozzle.
Old 12-25-2001, 02:45 PM
New User
gsrvx's Avatar
I really don't know anything about NOS...but does that mean that a wet system is safer....since it provides the extra fuel?
Old 12-25-2001, 03:07 PM
Default Re: which one is safer?? wet nos kit or dry zex kit?? (RK)
Not always wet systems are usually larger shots so they require more fuel, dry shots do not offer extra fuel because of their delivery they do not require it.
Old 12-25-2001, 05:06 PM
New User
gsrvx's Avatar
What's the biggest shot you'd go for with a dry kit? The reason I ask is that I'm going for a h22 swap soon...and some people tell me that lude motors respond well to nos. I guess I should start researching on dry, wet, direct port, plate systems, etc.
Old 12-25-2001, 06:47 PM
H22 I would do a Direct port 80 shot at a minimum H22 blocks are very strong, My buddy is running a 75 dry shot on his
Old 12-25-2001, 09:21 PM
New User
gsrvx's Avatar
thx man.
Old 12-25-2001, 11:43 PM
D Tranny Guru
Mista Bone's Avatar
Honda intake not designed to flow wet fuel, go dry or a true direct port setup.
Old 12-26-2001, 06:19 AM
GoQkRaCeR's Avatar
go with a Direct kit.. but WET is safer.. more fuel mixture. ive installed many wet kits on hondas.
itrhatch
Mid-Atlantic (Sales)
09-05-2006 01:00 PM
eg six
05-29-2006 05:45 PM
djtony5
02-24-2006 01:03 PM
BlackRocket
10-09-2004 07:48 AM
MooreBoost
02-18-2004 10:18 AM
Quick Reply: which one is safer?? wet nos kit or dry zex kit??
