zex nitrous kit help
ok i have a zex nitrous system on my eg hatch first let me start of by saying its a dry kit i havent sprayed because i want to convert to to a wet kit before i do what would i have to change/add to do this. Also the reason i want to do this is cuz my freind says haveing a dry kit will mess up my motor faster is this true or what is the differnce in dry and wet kit Thanks
Re: (eg six)
A dry kit only sprays nitrous into your engine. Your injectors supply the extra fuel needed.
A wet kit sparys both nitrous and fuel.
Both can be equally safe if hooked up and used right.
u would need to get a soleniod for the fuel, as you have one for the nitrous already, a diff spray nozzle that u can attach the fuel and nitrous lines to, jets for both.
Re: (Malakai)
dry is safe if you dont go over the 75 shot jet it comes with, and you retard your timing accordingly. i only run the 55 shot to be safe but its more than enough. you should spend money on a heater, gauge and purge kit if you dont already have it. have fun.
Re: (eg six)
zex sells solenoids and other parts seperatly. contact them or try http://www.summitracing.com
v-tec crx
13
12-26-2001 06:19 AM
