WTH!!! is a P28 Ecu
Old Apr 25, 2007 | 11:26 AM
RippSpeed's Avatar
Default WTH!!! is a P28 Ecu
Hey guys I'm kinda an old school honda guy (92 was the last year I touched a Honda) that recently return to the Honda scene...
I'm trying to get my little EG back to par and running order. I have a check engine light but I'm trying to figure out what a P28 is ... Sorry for such a noobie question
Old Apr 25, 2007 | 01:23 PM
slomofo's Avatar
GDD Member
92-95 Civic Si/EX ECU
SOHC VTEC engine code D16Z6 is the engine the ECU came with.
The most highly sought after ECU in the honda world because it will work on any H/B/F/D series motor except for the S2000's F20C/F22C and it doesn't have a knock sensor monitor.
Old Apr 25, 2007 | 01:45 PM
RippSpeed's Avatar
Default Re: (slomofo)
really ?!?!? No Knock sensor monitor, huh ... DAMN!!! I thought that would be the my check engine light... HHMMM!!! Do any you guys know where I can take this car to have check what wrong with it because the check engine light is pissing me off and probably holding me back in power in my B20B Vtec...
p.s. I'm in City Of Industries or Corona California
Old Apr 25, 2007 | 02:43 PM
shifts's Avatar
Default Re: (RippSpeed)
save a few bucks. https://honda-tech.com/zerothread?id=1901557.
Old Apr 25, 2007 | 02:54 PM
slomofo's Avatar
GDD Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RippSpeed &raquo;</TD></TR><TR><TD CLASS="quote">really ?!?!? No Knock sensor monitor, huh ... DAMN!!! I thought that would be the my check engine light... HHMMM!!! Do any you guys know where I can take this car to have check what wrong with it because the check engine light is pissing me off and probably holding me back in power in my B20B Vtec...
p.s. I'm in City Of Industries or Corona California</TD></TR></TABLE>
Your B20 doesn't have a knock sensor.
Old Apr 25, 2007 | 03:39 PM
RippSpeed's Avatar
DAMN!!!
thanks guys ... You guys just saved me some time thanx
I know the guy didnt put in the O2 sensor too, sooo that might be the problem...
Old Apr 25, 2007 | 04:02 PM
von_clutch's Avatar
so cant the p28 ecu werk with ls/vtec swap (b16 hed) considerin the b18b dosn't have a knock sensor then i wont hav to drill the blok..providin it can werk???
Old Apr 25, 2007 | 07:46 PM
aarontrini85's Avatar
Default Re: (von_clutch)
chip it and tune it and the p28 will run it
Old Apr 26, 2007 | 11:12 AM
von_clutch's Avatar
chip it how? and i thought all vtec ecu's require knock sensor inputs
Old Apr 26, 2007 | 11:41 AM
slomofo's Avatar
GDD Member
All DOHC VTEC ECUs have knock sensor monitors, but none of the SOHC VTEC motors have them, so that means no knock sensor monitor on SOHC VTEC ECUs.
Old Apr 26, 2007 | 02:02 PM
pgmfi.org is down right now so check this out
http://www.superhonda.com/tech....html
man you have alot of catching up to do lol
wtf did you do with a honda back in 1992 if you couldnt chip the ecu wtf kind of tuning could you do that was worth a ****?
Old Apr 26, 2007 | 03:47 PM
RippSpeed's Avatar
Default Re: (aarontrini85)
we were one of the first acura guys to use Accel Defi and we were one of the first guys to run 12's in palmdale in a integra
Old Apr 26, 2007 | 04:12 PM
awesome cant wait to see what you can do with the new tunning solutions
Old Apr 27, 2007 | 04:17 PM
RippSpeed's Avatar
I was told that I could run a P72 off a B16 Civic which would be better to run on my B20 Vtec; the P28 or P72 ????
Old Apr 27, 2007 | 04:21 PM
only diffrance is the map they come with from the factory but your replacing that any ways if you chip it to run that motor.
and the p72 supports a stock knock sensor but that thing sucks so go with the p28 its the bomb diggity
Old Apr 27, 2007 | 07:19 PM
DARKB20's Avatar
Hey Justin, just stay with the p28 and chip it...... You can use Chrome program to tune.. here's a good shop to go to......
Old Apr 28, 2007 | 06:34 AM
Crispy's Avatar
Default Re: WTH!!! is a P28 Ecu (RippSpeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomofo &raquo;</TD></TR><TR><TD CLASS="quote">
Your B20 doesn't have a knock sensor. </TD></TR></TABLE>
It might have a knock sensor depending on which b20 it is, mine does and I am not using it.
Check the Cell code forum in 92-2000 civic/del sol it is a sticky, and it will show you how to read exactly what code your ecu is throwing.
Old Apr 28, 2007 | 03:36 PM
RippSpeed's Avatar
Default Re: (DARKB20)
thanx for the info Jose... Yeah man I wish I could have afford your car because this one is giving more problems... OOOHHH well I'm stuck with it ... I guess I'll deal with it until I can afford a K20 Type R swap
brewbud
Nov 10, 2005 06:36 AM
hatchboy93
14
Apr 23, 2003 10:02 PM
lilxvtecxpwr
Aug 9, 2002 09:14 AM
