wont go into gear
Old Jul 18, 2007 | 12:31 PM
chocolatesk8er10's Avatar
Default wont go into gear
first off i have a 94 integra. Im not sure how many miles are on the clutch
yesterday i was driving and when i came to a stoplight and had it in neutral when it went green i tried to put it into gear and it wouldnt go into any gear! so i turned the car off and back on a magically it worked. The next day it happened again to me twice. and sometimes when coming to a stop sign i would push in the clutch and it would act like it wasnt in and the car would start to die. My dad thought it was the clutch fluid so i filled it up (it was about half an inch from the top. I turned on the car to drive it around the neighborhood to see if the problem was fixed and it wouldnt go into gear, even after i turned if off and back on! So my car is sorta stuck right where it is. Im gonna try and get it into the shop soon. But i was wondering if anyone had any input? can i just bleed the clutch fluid or is it something more major??? thanks in advance.
Old Jul 18, 2007 | 01:07 PM
slowcivic2k's Avatar
Default Re: wont go into gear (chocolatesk8er10)
Fingers on the pressure plate are not releasing pressure from the disc, may have a bad slave cylinder since it is intermittent. Try pumping the pedal several times and see if it still grinds. Is the slave cylinder leaking? pull the boot back on the slave cylinder and have someone push on the clutch, as see if it moves, or if it compresses on the release fork and then goes forward.
Old Jul 18, 2007 | 02:10 PM
Default Re: wont go into gear (slowcivic2k)
alright thanks alot man
Old Jul 25, 2007 | 11:24 AM
It was indeed the clutch springs, so i got a new Exedy clutch. Feels sooo nice, its not all notchy anymore. thanks for all the help guys!
Aaron Whitehead
Dec 14, 2018 08:29 PM
dunked dc
Jan 15, 2012 10:47 PM
92EG8
52
Nov 30, 2007 09:52 AM
chocolatesk8er10
Jul 25, 2007 11:24 AM
ouprimetime
Jul 8, 2004 09:57 PM
