wiring a cut off switch
Old Apr 18, 2002 | 10:43 AM
zdr262's Avatar
Default wiring a cut off switch
i want to wire a cut off switch for my ecu not on my battery..... would it be safe to run a toggle switch on the power wire on my ecu... so if somebody tried to steal my car the computer wouldnt turn on unless that switch was activated. I was just wondering if that would fry the computer and if not which wire is the main power for the ecu on a 92 civic hatch(color/location) that i could cut so the ecu wouldnt turn on. the only reason i ask is because i have had my car about stolen a few times my alarm didnt work to stop them. so i have just been taking my vafc out every night and its just a pain.
Old Apr 18, 2002 | 01:18 PM
Perfectionist's Avatar
Default Re: wiring a cut off switch (zdr262)
I wouldn't do the ECU power cut thing. The added wiring and switch may cause noise on the power feed depending on how/where you route the wires. E-mail me at Perfectionist_55@yahoo.com for some other suggestions, since I don't want to broadcast the ideas to potential thieves.
Old Apr 18, 2002 | 05:25 PM
tinkerbell's Avatar
Default Re: wiring a cut off switch (Perfectionist)
i would suggest putting the toggle switch on the main relay output to the fuel pump.
this is a good way to stop the engine starting...
make sure the switch can handle at least 20A at 15V or make sure you use a suitable relay(20A) and a smaller switch.
oh and make sure you dont tell anyone except your mom where the switch is
HTH,
t..
purposebuilt
Audio / Security / Video
13
May 3, 2019 03:38 AM
Kevinio
Mar 17, 2014 04:27 AM
nitewolf
12
Nov 21, 2009 08:55 PM
turbo-crx
Jan 9, 2009 09:58 AM
