wiring a 4 wire o2 sensor on 1 wire harness?!
Old Nov 15, 2002 | 06:33 PM
allmotor.net's Avatar
Default wiring a 4 wire o2 sensor on 1 wire harness?!
92-95 civic using p30 ecu
well i think i got some striaght directions, can any verify this as correct or if anyone has any different directions..
one black wire on o2 goes to a16 (orange/black)..... other black wire goes to yel/blk on injectors.....green goes to tps or air intake temp........ and white wire goes to c18 (but there is no c plug!!??)
Old Nov 15, 2002 | 06:40 PM
Desslok's Avatar
Default Re: wiring a 4 wire o2 sensor on 1 wire harness?! (allmotor.net)
Huh? Should be 2 wires to heat the o2 sensor, 1 wire is ground, and 1 wire is signal to ECU.
Old Nov 16, 2002 | 11:43 AM
Cynical 1's Avatar
You'll have to have a service manual or a wiring diagram.
Sounds like you're doing a swap. Tell us which one and it would help.
Old Nov 16, 2002 | 05:09 PM
Default Re: wiring a 4 wire o2 sensor on 1 wire harness?! (Revolveu2)
seems like i fixed it for now, fingers crossed.
92 cx jdm b16
p30 ecu
4 wire o2
stock cx harness
A25 (yellow/black) black
A6 (orange/black) - black
D22 (green/white) - green
D14 (white/red) - white
Old Nov 16, 2002 | 06:24 PM
drift's Avatar
New User
leave the white and gray wires disconnected. they're for heating the sensor.
attach the green to the original plug, and ground out the black.
single wire O2 sensors are designed without a sensor heater, and are internally grounded, thus only reqiring the signal wire.
Old Nov 17, 2002 | 02:50 PM
EG6owner-T's Avatar
Default Re: wiring a 4 wire o2 sensor on 1 wire harness?! (drift)
is that the same for the cx?
i got green for A26?
Old Nov 17, 2002 | 05:30 PM
drift's Avatar
New User
Default Re: wiring a 4 wire o2 sensor on 1 wire harness?! (EG6owner)
it's the same for all single wire O2 sensor applications
Old Nov 18, 2002 | 07:18 AM
EG6owner-T's Avatar
talkin to me?
Old Jan 13, 2003 | 09:31 AM
EG6owner-T's Avatar
92 cx jdm b16
p30 ecu
4 wire o2
stock cx harness
hey did you had a cel before the o2 wireup?
did you had one after?
i did the same as you but i still get the code 41, let me know thanks.
Old Jan 14, 2003 | 08:32 PM
EG6owner-T's Avatar
92 cx jdm b16
p30 ecu
4 wire o2
stock cx harness
Old Mar 6, 2007 | 01:39 PM
D15JDMARIO's Avatar
Default Re: wiring a 4 wire o2 sensor on 1 wire harness?! (EG6owner-T)
me too i tried.. the same and still got the cel..
Old Mar 8, 2007 | 03:36 PM
deftonerider's Avatar
its called rywire.com and its the easiest plug and play in the world
Old Mar 8, 2007 | 03:58 PM
t57b18's Avatar
Default Re: (deftonerider)
i would like to know how wire in a 4 wire o2 also.
Old Mar 8, 2007 | 04:10 PM
t57b18's Avatar
Default Re: (t57b18)
found this hope it helps
If you bought a CX or DX civic with a 1-wire o2 sensor, you're going to have to convert to a 4-wire to run a b-seires ecu, and most of the "top of the line" d-series ecu's like the p28.
First things first, you need to physically buy a 4-wire o2 sensor. you can't send a heater signal to a device which has no heater circuitry and expect it to work
Wires on 4 wire O2:
WHITE: Signal Wire
GREEN: Signal Ground
2 BLACK: Both black wires are the heater circuit wires.
Using a P28 ECU (and should work for most obd1 ecu's with 4-wire controls)
Run O2 Sensor signal (white) To D14
Run O2 Sensor signal Ground (green) to D22 (or any good Ground)
Run O2 Sensor Heater Circuit Control (black) to A6
Run the other black heater circuit power wire to (A25) or any good switched +12VDC source.
(you may mix up the black wires... if car dies after it is warm/10-30 seconds, that's the first thing to swap over and troubleshoot.. theres no way to tell one from the other by looking at them)
CrxB16a2
Apr 8, 2013 06:28 AM
killafred187
Jan 27, 2008 09:55 AM
Ronan
May 22, 2007 08:48 PM
V3locity
Jul 24, 2004 06:32 PM
alexb16hb
Mar 23, 2004 01:48 PM
