Will a knock sensor retard timing w/o tripping CEL??
Old Apr 22, 2004 | 02:27 PM
Trac226's Avatar
Default Will a knock sensor retard timing w/o tripping CEL??
I think I might have split my knock sensor while disconnecting it. The CEL has not come on but my idle gets really irradic, unless I rev past 2k.
If it's not the knock sensor, then my problem has to lie with my tps. Thanks.
Old Apr 22, 2004 | 03:19 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: Will a knock sensor retard timing w/o tripping CEL?? (Trac226)
the job of the knock sensor is to pull the timing when it detects detonation, if the sensor is malfunctioning but still reports itself to the ECM that could cause problems.
stan
Old Apr 22, 2004 | 06:40 PM
Trac226's Avatar
Default Re: Will a knock sensor retard timing w/o tripping CEL?? (Stan D)
Alright, I can confirm that the knock sensor will retard timing even if it does not trip the CEL.
My car now does show code 23 which is the KS and if anyone has a conversion harness out there, please let me know, I think I'll just switch to a p28
Old Apr 23, 2004 | 12:35 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trac226 &raquo;</TD></TR><TR><TD CLASS="quote">Alright, I can confirm that the knock sensor will retard timing even if it does not trip the CEL.
My car now does show code 23 which is the KS and if anyone has a conversion harness out there, please let me know, I think I'll just switch to a p28</TD></TR></TABLE>
I sell converion harnesses.
what type are you looking for exactly ? obd-0 to obd1?
IM if you're interested
Old May 1, 2004 | 12:54 PM
1SlowSi's Avatar
Default Re: Will a knock sensor retard timing w/o tripping CEL?? (Katman)
So when you have knock/detonation, the computer will automatically retard the timing? To what though? And when it does, does it stay like that or would you still have to retard it yourself to prevent it from happening again?
Old May 2, 2004 | 03:00 AM
1SlowSi's Avatar
bump.
Old May 3, 2004 | 01:45 AM
1SlowSi's Avatar
Default Re: Will a knock sensor retard timing w/o tripping CEL?? (1SlowSi)
bump
Old May 3, 2004 | 10:37 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SlowSi &raquo;</TD></TR><TR><TD CLASS="quote">So when you have knock/detonation, the computer will automatically retard the timing? To what though? And when it does, does it stay like that or would you still have to retard it yourself to prevent it from happening again?</TD></TR></TABLE>
Not fully sure on how far the ecu kicks back the timing, but its about 15 degress or so from what I remember. Its lame, you can totally feel the loss in power/hesitation when the ECU pulls back on the timing too. It doesn't stay stuck at 15 degrees, it only kicks it back whenever the ecu detects knocking. The only real way to prevent the ecu from pulling back on timing is by checking to see what your ignition timing is set to (should be set between 16-18 degrees), or by simply using an ecu that has a disabled KS.
96hatchBoy
Sep 17, 2012 06:57 PM
co_OlLo_OdDo_Od
May 3, 2006 11:36 PM
92eh3si
Oct 24, 2004 10:22 PM
H23vtecEG
May 18, 2003 10:04 AM
