Knock sensor?
Old May 18, 2003 | 07:10 AM
H23vtecEG's Avatar
Default Knock sensor?
i rebuilt my friends GSR with JE 11:1 pistons, and sometimes the thing throws the Knock sensor code, well it throws it everytime all the time
should i retard timing a bit, will that fix the problem? anything else i can do
Old May 18, 2003 | 10:04 AM
Kataku2K3's Avatar
Default Re: Knock sensor? (H23vtecEG)
Is your KS wired up??? That's the most common problem for a constant knock CEL... What is his timing at?? You should easily be fine even at up to ~18 degrees with 11.0:1 and good gas... Good Luck
mxracer420
Apr 27, 2009 08:44 PM
civicgsr499
14
Nov 13, 2008 06:28 PM
98vtec
Aug 18, 2006 07:12 PM
co_OlLo_OdDo_Od
May 3, 2006 11:36 PM
Trac226
May 3, 2004 10:37 AM
