Wierd prob with ignition help please!!!
Old Jan 24, 2003 | 03:38 PM
leadfoot78's Avatar
Default Wierd prob with ignition help please!!!
Ok this is the first problem after the swap. I decided to buy a timing gun and check the timing cuz I replaced the timing belt and took off the distributor a few times. Warmed up the car turned it off jumped the connector hooked up the timing light. I go to turn on the car and it starts then the rpms slowly fall and the motor dies. I try to start again it starts but quickly dies again. After disconnecting the damn timing gun the fuel pump wont prime. I left for a few hours came back and everything is fine car started and i drove it around all is good. Then with the gun hooked up the same thing happen again. Anybody know anything about this???? i need help bad.
REDBARON
26
Apr 1, 2017 08:20 PM
slow-ef
Mar 26, 2009 10:53 AM
thebleek
17
Sep 3, 2008 06:04 PM
wpgcivic
Jan 16, 2005 06:15 PM
leadfoot78
Jan 25, 2003 02:38 PM
