what wire should i use for inline pump?
Old Sep 12, 2003 | 05:49 PM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default what wire should i use for inline pump?
I know that you can tap into the grn/ylw wire in the main relay but i cant get to it...the people before me installed an alarm system directly over the damn thing. What other choices do i have? Im a little leary about sending a wire under the car to the actual fuel pump. Is there anything i can use inside the engine bay? BTW its a 90 crx with a turbod LS.
Sean
Old Sep 12, 2003 | 06:24 PM
sCeRaXn's Avatar
Default Re: what wire should i use for inline pump? (sCeRaXn)
ttt
sean
Old Sep 13, 2003 | 08:54 AM
sCeRaXn's Avatar
Come on people...i know someone has wired up a inline pump before...
Sean
Old Sep 13, 2003 | 11:21 AM
sCeRaXn's Avatar
Yea...thanks for the help. I thought that the point of this board is was to help people? At least thats how it was a couple years ago...
Sean
Old Sep 13, 2003 | 12:14 PM
highmilehatch's Avatar
I always tap that off the fuel pump relay, but if you can't access it, you could always run a power wire from the battery, two a two prong switch (probably not the right term but you get the idea), and run the other end of the switch to the positive on the pump. Ground the pump. Flick the switch and the pump will turn on. Just don't forget to turn the switch off when you turn off the car or else it will keep running.
00trdtaco
Aug 20, 2009 06:42 AM
crxfreak1117
Aug 15, 2009 06:09 AM
Civic Si Kid
Audio / Security / Video
May 17, 2009 12:26 PM
ridnmyhonda
Feb 13, 2003 04:23 PM
Arturbo
Jan 27, 2002 02:34 AM
