where is this leak coming form?!
Old Mar 15, 2004 | 05:46 PM
iwhichisme's Avatar
Default where is this leak coming form?!
okay, ive been noticing that im having to fill up my clutch master cylinder reservoir more often than not. My issue is, i dont know where the hell the leak is. I keep having to fill it up, and beg one of my girlfreind to help me bleed it . Any help would be appreciated, as this is starting to get on my nerves.
chaz
Old Mar 15, 2004 | 07:01 PM
doublejz's Avatar
Default Re: where is this leak coming form?! (iwhichisme)
sounds like your master cylinder is starting to take a **** on you.
Old Mar 16, 2004 | 06:28 AM
iwhichisme's Avatar
Default Re: where is this leak coming form?! (doublejz)
youre referring to the clutch master cylinder right? Ive checked that and it seems ok, there doesnt seem to be any leaks coming from it.
Old Mar 16, 2004 | 07:23 AM
CHEETAH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iwhichisme &raquo;</TD></TR><TR><TD CLASS="quote">okay, ive been noticing that im having to fill up my clutch master cylinder reservoir more often than not. My issue is, i dont know where the hell the leak is. I keep having to fill it up, and beg one of my girlfreind to help me bleed it . Any help would be appreciated, as this is starting to get on my nerves.
chaz</TD></TR></TABLE>
prolly each one of your girlfriends are taking turns emptying out your clutch reservoir ... lol
usually leaks are at master cylinder or the slave cylinder.
greg
Old Mar 16, 2004 | 10:59 AM
AL ASPIRATED's Avatar
if u master cylinder seems fine, check ur slave cylinder.
just take a small pick or srcew driver and move the rubber boot on the slave cylinder, u would notice a good amount of fluid come out.
Old Mar 16, 2004 | 11:26 AM
JimBlake's Avatar
Default Re: (AL ASPIRATED)
If it's your master, maybe it's leaking thru the firewall, soaking into the padding beneath the carpet.
Old Mar 16, 2004 | 05:47 PM
iwhichisme's Avatar
Default Re: (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">If it's your master, maybe it's leaking thru the firewall, soaking into the padding beneath the carpet.</TD></TR></TABLE>
thats what im thinking it may be, but how would you check from inside the car for leaks. or what is a possible
Old Mar 16, 2004 | 05:48 PM
doublejz's Avatar
Default Re: (iwhichisme)
just crawl under the steering wheel and look, or take out the two bolts that have the dummy pedal thing on the left and roll your carpet back some
juniestyle
Feb 19, 2008 03:43 PM
-Championship-
Apr 8, 2007 01:06 PM
TurblowR
Mar 28, 2005 06:26 PM
old_school_dohcvtec
Dec 2, 2004 10:51 AM
93H22A
Apr 9, 2004 10:46 PM
