slave cylinder problems
Old Apr 8, 2007 | 12:18 AM
-Championship-'s Avatar
Default slave cylinder problems
about a week ago Ive been having problems with the clutch, i opened the reservoir and found no fuid at all, so i put some more (about a few ounces) and clutch pedal felt better. i changed the master about a month ago, do i need to replace the slave cylinder?
Old Apr 8, 2007 | 05:50 AM
HondaKyle's Avatar
Default Re: slave cylinder problems (CW_98gsr)
mine broke with only 38K miles you should get one now so when it does brake your not paying the honda dealer 300 dollars for a 150 dollar part
Old Apr 8, 2007 | 07:51 AM
Dogginator's Avatar
Daisy... Daisy...
You need to find the leak. Just because the master cylinder is new does not mean it cannot be leaking. Top off the reservoir, wipe everything down near the master and slave cylinders, and press the clutch about 100 times. Search for leaked fluid.
Old Apr 8, 2007 | 01:06 PM
Default Re: slave cylinder problems (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">You need to find the leak. Just because the master cylinder is new does not mean it cannot be leaking. Top off the reservoir, wipe everything down near the master and slave cylinders, and press the clutch about 100 times. Search for leaked fluid.</TD></TR></TABLE>
good idea thanks
juniestyle
Jan 25, 2008 02:31 PM
TurblowR
Mar 28, 2005 06:26 PM
RiCE On IcE 2
Mar 6, 2003 03:47 PM
-BlueGSR-
Dec 21, 2002 07:30 AM
