When Plastigauging Rod Bearings...
Old Aug 8, 2003 | 04:46 AM
slofu's Avatar
Default When Plastigauging Rod Bearings...
how do you guys prefer to disconnect the caps from the beams (since they are dowelled)? i'm trying not to smear the plastigauge by moving the rods. (i wish that i had longer studs without caps which i could thread in and tap.)
Old Aug 8, 2003 | 08:24 AM
BeerMan's Avatar
Default Re: When Plastigauging Rod Bearings... (slofu)
take a plastic, rubber, anthing other than metal, hammer and tap as you pull up on the cap. It takes a little persistance to get some of those caps off.
Old Aug 8, 2003 | 01:06 PM
senpai's Avatar
Default Re: When Plastigauging Rod Bearings... (BeerMan)
Yea, I use those $1 rubber hammers and whack at it until there's enough room for me to slide a small flathead screwdriver in to lightly pull it off.
Old Aug 8, 2003 | 01:09 PM
zeke's Avatar
Default Re: When Plastigauging Rod Bearings... (maztur)
i try not to hammer on the rod bolts, use a pair if big channel locks instead
C Hustle
Feb 17, 2010 06:21 PM
geebs
May 17, 2007 10:41 AM
HmgLauj69
Mar 21, 2005 11:13 AM
dwilson
Mar 4, 2003 08:13 AM
Evil EG
Jan 20, 2003 10:39 AM
