Rod Caps...
Old Jan 20, 2003 | 09:52 AM
Evil EG's Avatar
Default Rod Caps...
Ok I got one of my Eagle rods on the crank cause I was plastigauging. I goto Take the Cap off and I cant get the damn thing to come off. The Caps have little dowels that go into the rod that make it hard? For the next three should I spray wd40 in the whole b4 so its easier to remove?
Old Jan 20, 2003 | 10:00 AM
dustin's Avatar
Default Re: Rod Caps... (BVM)
stick a screwdriver in the hole and carefully wiggle back and forth
Old Jan 20, 2003 | 10:17 AM
earl's Avatar
Unscrew the rod bolts a few turns and gently tap the top of the bolt. The bolt will push the rod away from the cap
Old Jan 20, 2003 | 10:33 AM
TurboTegB18c's Avatar
Default Re: Rod Caps... (dustin)
Use your muscles, and wiggle the caps back and forth. It'll eventually come apart.
Old Jan 20, 2003 | 10:39 AM
Evil EG's Avatar
Default Re: Rod Caps... (TurboD16Z6)
LOL yea ok. Those things are tight. Thanks for your help guys much easiers.
weekendboost
Engine Machining & Assembly
Oct 17, 2017 10:40 PM
turbociv910
Aug 6, 2010 07:10 PM
RTW DC2R
Jul 16, 2004 05:55 AM
B18EG6
Jun 30, 2004 04:15 PM
slofu
Aug 8, 2003 01:09 PM
