Need pics of B16a intake manifold
Old Aug 8, 2003 | 12:52 PM
zippeay's Avatar
Default Need pics of B16a intake manifold
Hey whats up, I have a 92 civic cx with a B16a SIRII, anyway my idle's been messed up since I had it put in. The guy put my map sensor Tee'd into the line between the fuel pressure regulator and the intake manifold. I don't think its supposed to be like this and I think that's the reason my idle is screwed up. Anyway does anyone have a really good pic of the whole intake manifold so I can were this map sensor is connected to? Please help, thanks
Old Aug 8, 2003 | 01:20 PM
irev210's Avatar
Default Re: Need pics of B16a intake manifold (zippeay)
on the JDM SIR II the fpr vacuum connects straight to the intake manafold
the map sensor is located on the throttle body. If you have a 2nd gen XSi, then there is a port that comes off the throttle body... take that and put a vaccum hose to that and connect any map sensor to that.
Old Aug 8, 2003 | 02:25 PM
zippeay's Avatar
Ok I don't have a map sensor on the throttle body its screwed to the fire wall "not by me". There are two vacuum line coming from the TB and there both going a canister right below my fuel filter. Are the vacuum lines supposed to go to the canister? If so do I tee into one for my map sensor??? If I do then which line, the one on the very top of the TB or the one off to the right side? Hey thanks a lot man
chris3385
Jan 3, 2009 04:49 AM
LUKE 92 GS-R
Jun 18, 2008 06:17 PM
88 rex
Aug 16, 2005 06:49 PM
fast93accord
May 23, 2005 09:31 AM
The Mole
Nov 23, 2002 10:22 AM
