Wobbly wheel.
Wobbly wheel.
My back right wheel is not straight and wobbles a bit. We took my wheel out cleaned the breaks inspected it and put it back together and it was still wobbly less but still a little bit. my lug nuts are tight and its not my rim. we took it apart again and started spinning the hub it started wobbling a bit do you think it could be that? or it looks like its wobbly because part of it is dirty and when you spin it it looks like its wobbling. Any ideas?
Re: Wobbly wheel.
more than likely its you wheel bearing i had the same problem
lift up your car and move the tire if if wobbles bad then you need to replace to wheel bearing in some cases its probably cheap just to go to the junk yard and pull one off for like 50 buck because the wheel bearing from autozone it self cost around 60 and then you still have to get the wheel bearing compressed in
