Torque wrench
Old May 26, 2003 | 05:39 PM
Hayasa15's Avatar
Default Torque wrench
Hey guys i was looking at somethings today and started to wonder how do i use my torque wrench? In my Chiltons manual is says that some things need to be tightened in in/lbs but my torque wrench only reads in ft/lbs so i am figuring that you would set the wrench going by the fact that there are 12 inchs in 1 foot. Is this correct? If so then 108 in/lbs would be 9 ft/lbs, right?
Old May 26, 2003 | 06:39 PM
tilt's Avatar
Default Re: Torque wrench (Hayasa15)
right... when it gets that low your torque wrench prob isnt accurate at all, esp if you have a 1/2" drive with only ft/lbs as measurements. Im sure if you find a smaller torque wrench though it can be faily accurate. But for me, anything around 10ft/lb or less I just do it by feel and do it hand tight. More consistent this method imo.
Old May 26, 2003 | 08:06 PM
Ryan C's Avatar
Default Re: Torque wrench (tilt)
w0rd
i've tried to do the lower torques with a t-wrench and snapped stuff before
hand tight is the way to go with small numbers
Old May 26, 2003 | 09:12 PM
blah13's Avatar
Default Re: Torque wrench (Ryan C)
I grabbed a 3/8 0-75lb needle t-wrench for my small things for like $15 and got the massive 1/2 25lb-250lb click t-wrench for the big stuff...I tell you what though, anything over 25 I use the click, hella lot more leverage, 132lb on the axle nut was cake *click click* done.
Old May 27, 2003 | 05:29 AM
Hayasa15's Avatar
Default Re: Torque wrench (blah13)
Thanks alot guys
arren123
Jul 20, 2010 12:51 PM
EG-SIXV-TEC
Honda Civic (2001 - 2005)
Apr 7, 2009 07:32 PM
EG-SIXV-TEC
10
Apr 2, 2009 07:43 PM
smxcan
Jan 12, 2009 07:17 PM
