What should Coolant Temp Be????
Old Jul 29, 2004 | 01:32 PM
FwdCivicHatch's Avatar
Default What should Coolant Temp Be????
What should my coolant temp be? B18c1
Old Jul 29, 2004 | 02:26 PM
suspendedHatch's Avatar
Default Re: What should Coolant Temp Be???? (FwdCivicHatch)
180F
Old Jul 29, 2004 | 03:08 PM
TrackWeapon's Avatar
Default Re: What should Coolant Temp Be???? (shaundrake)
the ideal temp for the most efficiency of engine is at 93C or 200F
Old Aug 1, 2004 | 01:33 PM
Default Re: What should Coolant Temp Be???? (TrackWeapon)
so 210 F to 230 F isn't great but it's not that bad either???
Old Aug 3, 2004 | 10:30 AM
Running that hot is going to wear down your engine faster. Change your oil more often at least.
Old Aug 3, 2004 | 02:23 PM
99B16Si's Avatar
outside temps have a pretty large effect on your coolant temp. down here in florida itll get up to almost 100deg during the day and ill see coolant temps approach close to 220deg at times. but at night sometimes i wont see over 190deg. my factory temp gauge didnt move past its normal sitting point until 228-230degrees and would go up about an 1/8 of the way per 1 degree. this was according to the aem ems when i had it
philliedawg
13
Feb 8, 2010 07:29 PM
redline870
Feb 6, 2009 02:57 AM
brucepick
Nov 22, 2008 04:02 AM
sleepystyle
Apr 19, 2006 04:34 PM
D15B7
Mar 10, 2003 02:29 PM
