Coolant temp and t'stat
'97 Civic HX, 5-spsd.
My ScanGauge shows coolant temps between 177 and 181 deg. F.
My Haynes manual says t'stat thermostat rating is 195 deg. F.
Should my coolant temps be more like 195 or 200 deg. F instead of 177-181?
New t'stat was installed about 6 weeks ago, the shop said they got the t'stat from Honda.
Should I replace it AGAIN with another?
Yes, the t'stat is functioning. Temp stays very even, just goes up and down a few degrees if I do a long downgrade or upgrade or any other major lengthy changes in engine load. You can't see it on the dash gauge, just on the ScanGauge because that's digital and reads the computer's output.
What is the water temp supposed to be on these cars?
I've never had issues of it. I think we're well in range, we could even be in the margin of error, there's no telling how accurate the ECT is anyway.
I occasionally get hits up to 190, but it cools down soon enough.
Edit: Also some fun trivia: While unplugged, -40 F (that's how I knew my ECT blew ) and when wires cross, 418 F (I shat myself and killed the ignition).
(offtopic: also, our cars are held together by 10mm headed bolts.)
toohott4handlin
21
02-08-2004 03:47 AM
