what pistons to get with my setup
Old 02-15-2003, 01:35 AM
TypeR0wnz
Guest
Posts: n/a
Default what pistons to get with my setup
If u have a b20 with a b16 head and are running stock pistons and want to run higher compresion and plan on upgrading the cams and vlvetrain to type r what are better pistons to get itr or ctr. im thinking the ctrs compression will be too high for what im running and the itr will be alright. I want to get a better valvetrain and cams but am afraid of bending the stock rods so I think the itrs will work fine what do u guys think. details on comments please
Old 02-15-2003, 01:37 AM
VTEC-DA's Avatar
Default Re: what pistons to get with my setup (TypeR0wnz)
What does bending the stock rods have to do with anything? What would cause them to bend?
Old 02-15-2003, 02:08 AM
Dual Cams's Avatar
get the JE 84.5mm 12.5 C/R pistons. you'll be fine with pump gas, They are rated 12.5 C/R but i think is over rated on the compression.
Old 02-15-2003, 04:39 AM
lazy bum shaughn's Avatar
Default Re: what pistons to get with my setup (Dual Cams)
Yea JE makes some good pistons. CTR/ITR pistont wont even fit in the 84mm bore.
Old 02-15-2003, 11:01 AM
New User
NSX Bob's Avatar
As stated, the largest bore you can get ctr pistons in is 81.25 (same w/ itr). There is nothing you have indicated that should result in bent rods, so if you do change pistons to another honda oem piston, there is no reason to change the rods.
Old 02-15-2003, 02:55 PM
MrFatBooty's Avatar
This is somewhat dependent on what your goal is for the end-result CR. The stock B20B pistons will yield about 9.1:1 CR when used with a B16 head. JE has a couple of options for B20/VTEC applications. One is supposed to yield a 10.5:1 CR and has a dome volume of -1.7 cc. When plugged into the formula for static CR this yields a result of 10.35:1. The other option has a dome volume of 4.8 cc, JE says it'll be a 12.5:1 CR, the formula says about 11.7:1.
Old 02-15-2003, 03:06 PM
96-EJ6 B18C's Avatar
Check out the compression ratio calculator in the how to section of http://www.c-speedracing.com you will be able to figure out what compression you will get using various parts.
cleanem1509
14
02-01-2010 08:27 AM
CaseBone
32
04-03-2007 05:15 AM
mugen12_35sec
04-13-2006 04:20 AM
greasemonkeys
01-07-2005 06:41 PM
TypeR0wnz
02-15-2003 03:46 AM
Quick Reply: what pistons to get with my setup
