Where does the top port on a tial wastegate go to?
I have a tial wastegate. I had only hooked up the side port, then I saw that for boost control I have to "add air to the top port". How do I do that?
Any pictures or comments will help.
Thanks.
Thanks.
Re: Where does the top port on a tial wastegate go to? (evilhatch2.0)
on the tial wg the top port is for an ebc (Electronic Boost Controller) the side port is for a Manual boost controller. The key is to get the vac line on the BC as short as possible.
EBC = top port and side port
MBC or no BC = side port....also this port is T-ed into a vacuum source (after throttle body).
Re: Where does the top port on a tial wastegate go to? (blackeg)
How about if you dont have a BC at all. With one goes connected to the turbo?
Never mind I just notice, on the side one.
but I am using an EBC, I have attached the side port to the solenoid and the solenoid the the intake charge(before throttle body).
The EBC only has 1 inlet, and 1 outlet, where do I plug in the top one?
turbosol18
09-03-2007 01:19 PM
1baddturbosi
12-10-2006 08:12 AM
