vtec pressure switch
Old May 28, 2009 | 10:47 PM
  #26
aasarsak's Avatar
Default Re: vtec pressure switch
last one
  #27
dave181's Avatar
i can reed the big wording not therest if u can blow the hole thing p id apreciate it thanks man for all ur help
Old May 28, 2009 | 10:48 PM
  #28
aasarsak's Avatar
better?
Old May 28, 2009 | 10:56 PM
  #29
dave181's Avatar
yea much beter man thanks i dont know how to do the presure chek and i dont got the tools to do it this is a pain in the *** lol
Old May 28, 2009 | 11:00 PM
  #30
aasarsak's Avatar
well, according to the flow chart, you have 2 options: either buy the oil pressure gauge (which is the only tool you're missing to run the diagnosis), or replace the ECU. I'm pretty sure it will be cheaper to buy an oil pressure gauge. I bet it would even be cheaper than having a shop diagnose it for you...
  #31
aasarsak's Avatar
Oh, and you're welcome.
Old May 28, 2009 | 11:22 PM
  #32
dave181's Avatar
where would i pick up the gauge at and how much u think itwould run me to pic up the tool
Old May 28, 2009 | 11:26 PM
  #33
aasarsak's Avatar
$20 - $100
Any auto parts store should have one (auto zone, kragen, pepe boys, etc.)
Just get a cheap one, or better yet, see if they will rent you one...
Old May 28, 2009 | 11:30 PM
  #34
dave181's Avatar
never thought to ask if they could rent one out i think ill give it a shot and go ask around tomarrow and see wats up im just afraid that itll cost alot to fix it when i find out whats fukd up lol. what i dont get is what would puting a new ecu do to fix the problem im confuesd there
Old May 29, 2009 | 01:38 AM
  #35
aasarsak's Avatar
just follow the troubleshooting steps. They are laid out in such a way that it starts with the smallest problem first, and then gets bigger. That's why the ECU is listed last in the troubleshooting procedure.
It is always cheaper and better to diagnose and fix it yourself.
Old May 29, 2009 | 03:26 PM
  #36
dave181's Avatar
i went and used my multimeter and im not geting anything at all now what should i do i turned the key to acc and did the multimeter and it didnt do a thing at all help
Old May 29, 2009 | 03:27 PM
  #37
dave181's Avatar
aasarsak thanks for all your help bro i still need more lol
Old May 29, 2009 | 06:36 PM
  #38
dave181's Avatar
delsolproblems i would also like tothank u as well for urhelp
Old May 29, 2009 | 06:37 PM
  #39
dave181's Avatar
anyone else wana take a wak at my problem
Old May 29, 2009 | 08:06 PM
  #40
delsolproblems's Avatar
Check the voltage across the battery terminals with the meter on the same setting to make sure you're getting a reading. You should see around 12v. If you do, the meter is set correctly. If you get no voltage between the switch power wire and the battery ground, then test the switch ground wire. Turn the meter dial to ohms- the symbol looks a little like a Q, you can find it on google. The meter will likely have a 1 shown. Connect the red probe from the meter to the ground wire on the harness side of the switch connector and the black probe to the neg battery terminal. If it changes to zero then the ground wire is good and only the power wire is broken. If it doesn't change, both wires are disconnected. If the 1 changes to any other number post it here. Follow any broken wires and look for the break. You can use the meter on the ohms setting to see if a wire has a break between the two points you connect the probes to. As I said, if the one changes to a zero then there's a good connection, no change is no connection and anything in between is a partial connection.
Old May 29, 2009 | 10:56 PM
  #41
dave181's Avatar
yea i tryd it on the battery and it workd where should i look for breks at
Old May 29, 2009 | 10:57 PM
  #42
dave181's Avatar
i meen were r some comon areas that i can find them at
Old May 29, 2009 | 11:12 PM
  #43
aasarsak's Avatar
Where did you put the multimeter leads? What setting was it on? Are you following the diagnostic procedure I posted for you? Just follow the flow chart, it lays it out for you step by step. It's pretty much a no-brainer. Just follow the procedure.
Old May 29, 2009 | 11:19 PM
  #44
dave181's Avatar
i used the seting delsol told me to use i put the the leds on both conectors and switchd them and tried it the other way as well ive never used a multimeter till today so im trying my best lol thanks again
Old May 30, 2009 | 12:43 AM
  #45
aasarsak's Avatar
You're welcome. Basically you only need to use 2 settings. One is for volts, and the other is for ohms. Use ohms where the service manual say to "check for continuity." Use volts where it says "check for voltage."
Remember, never use ohms on a powered circuit.
Old May 30, 2009 | 07:08 AM
  #46
If the power wire has no power and the ground shows no continuity then first check for an unhooked connector since it's unlikely both wires broke at the same time. If the ground is good, then follow the power wire and check for resistance (ohms) until you find a section of the wire where the 1 on the meter doesnt change (meaning a broken connection). In either scenario, follow the wires and check for resistance on both sides of any connectors to see if they are good. Usually the meter probes have a sharp point that you can stick right into the sheath of the wire when testing so you wont have to strip the wire. Cover all holes made like this with electrical tape.
Old May 31, 2009 | 09:27 AM
  #47
1sikhatch's Avatar
im having the same problem with mine, i hook up power the the vtec solenoid and it clicks, good oil pressure, no cel and vtec wont pop
Old May 31, 2009 | 10:59 AM
  #48
aasarsak's Avatar
VTEC is a very dependant system. What I mean by that is if the ECU detects anything malfunctioning, it will prevent VTEC from engaging, so if you have a CEL, you will have to clear that before the ECU will allow VTEC to engage. If you have no CEL, follow the diagnostic procedure I posted above.
KiDDD...
Mar 27, 2012 06:11 PM
fongck88
Jan 21, 2009 05:29 PM
sol2hatch
Mar 5, 2006 06:50 AM
NobodysHero
Jul 10, 2004 08:10 PM
