vtec not completely engaging
Old Oct 13, 2002 | 08:19 AM
burner's Avatar
Default vtec not completely engaging
well i have a friend that has a b16 turbocharged.....but his vtec is malfunctioning. it sorts of sputters when it engages and it does this for a few second then it clears up then the rpm goes on normally(above 6000rpm) well so far we check almost everything...oil pressure,VSS,etc...and he also put the oil pressure line for the turbo from the front of the head......into that little 10 nut infront of the head, would this play a factor for the oil pressure loss..as of now we dont know what to do..can this be mechanical or electrical problem?
Old Oct 16, 2002 | 09:31 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: vtec not completely engaging (burner)
it's engaging, it's just bogging. get a vtec controller so you can move the VTEC point around.
Old Oct 16, 2002 | 10:09 AM
torr's Avatar
Default Re: vtec not completely engaging (dLo GSR)
your fuel is cuttin out
Old Oct 16, 2002 | 10:35 AM
hondaman739's Avatar
Are there any internal modifications? Is your oil pressure dropping at that point? What turbo do you have? More info would help...
Old Oct 16, 2002 | 01:31 PM
MikeMAN's Avatar
i think it may be where the oil line is tapped..
why didn't he just tap it by the oil sending unit?
Old Oct 16, 2002 | 07:12 PM
burner's Avatar
Default Re: vtec not completely engaging (MikeMAN)
i think its a drag kit maybe will try to move the oil line
Old Oct 16, 2002 | 07:19 PM
MikeMAN's Avatar
okay, keep us updated!
Old Oct 16, 2002 | 08:51 PM
bruthaboost's Avatar
FYI: your oil feed line is coming right off the oil gallery that feeds your spray bars and rocker arm dowels. I had mine there and I'm moving it.
hth
Old Oct 17, 2002 | 10:15 AM
Mover's Avatar
Default Re: vtec not completely engaging (bruthaboost)
You said you checked your oil pressure. What oil pressure readings are you getting at the switch over point ? Did you check your solenoid valve ?
[Modified by Mover, 2:15 PM 10/17/2002]
Old Oct 17, 2002 | 10:55 AM
raene's Avatar
Yes, that's the oil pressure test location for the VTEC solenoid. You're definitely not supposed to have the oil feed there...
Old Oct 17, 2002 | 07:50 PM
burner's Avatar
Default Re: vtec not completely engaging (Mover)
how much pressure am i suppose to expect from that and the x over......and yup we checked the solenoid and we even switch the solenoid with mine
madcrx69
Apr 17, 2010 05:31 AM
EG Boostin
Feb 2, 2007 10:21 AM
Griffin@Camtech
Feb 24, 2004 05:58 PM
b20b
Feb 22, 2002 03:46 AM
b20b
Feb 22, 2002 03:42 AM
