VTEC ECUs.......any can be used for any correct?
Okay, I will just let you know what I am thinking now.
HX has roller rockers. EX has a better fuel map
Custom HX cam from Crower. EX ecu to get rid of the lean burn?
So in effect it would be a roller rockered VTEC engine......
How would you intend on locking those "other" 4 valves at 3500rpm or whatever if you remove the HX ECU?
[Modified by VTC_CiViC, 12:05 PM 6/19/2002]
VTEC is just a solienoid that turns on.....the only issue would be VTEC would the cross over would be 5500 instead of 3000.
I think. That was the dumb point in my poorly worded question. Isn't VTEC just a signal to a solenoid to turn on? If so, I could swap the ECU and get a better cam and whala......no more lean burn.
Would need the cam because the HX cam sucks right at 2900........can feel the difference (when trying) of the lobes.
I wasn't aware the Y5 used the same style soleniod as the traditional VTEC's use.. that being said, yea I suppose you can alter it with an AFC no problem, you also get to start off with lower CR lucky bastard
BTW I've got my old EX ECU laying around
[Modified by VTC_CiViC, 12:24 PM 6/19/2002]
Interesting.....wonder how a stock D16Y5 is gonna react with a EX ECU
Stay tuned to find out......ROFL
95-CivHB-VX
Aug 22, 2004 08:07 AM
pbomers
Aug 14, 2004 01:09 PM
