vtec?
when i turn off the car and start it back up, the check light disappear. But i tried checking the code while the car is running and received code 21...i just replace the vtec solenoid with a new one too so couldnt be that
I had the same problem when I hooked up my VTEC light. Do you have any connections spliced off the solenoid wire? If so, try soddering the spliced wire to the original vtec wire, that should solve. If not, make sure all connections to and from the solenoid are secure and soddered.
jB
jB
vtec will pull one time then i would get check light.....i've gotten a mechanic to rewire my harness and he has check it out but said its the ecu....
b16a 93 hatch
b16a 93 hatch
I'm having a similar problem, but my vtec has never worked (but the solenoid is not bad). going through the helms manual points right to the ecu. I just think it's fishy that only the vtec activation could go "bad" in an electronic piece of equipment like the ecu. but what do I know...
Pr0ject93hb
Sep 14, 2007 09:50 AM
thangbui
Oct 23, 2005 08:05 AM
