vtec?
Old Apr 25, 2002 | 05:16 PM
Eg6_JDM's Avatar
Default vtec?
change vtec solenoid, vtec work. works only for one time then check lights turns on. ill have to turn off the car and start it again inorder to have vtec. Any thoughts?
Chris
Old Apr 26, 2002 | 07:54 AM
Eg6_JDM's Avatar
Default vtec?
anyone? any ideas
Old Apr 26, 2002 | 07:56 AM
E-AT_me's Avatar
Default Re: vtec? (Eg6_JDM)
what code?
Old Apr 26, 2002 | 08:01 AM
Eg6_JDM's Avatar
Default Re: vtec? (Rexman)
when i turn off the car and start it back up, the check light disappear. But i tried checking the code while the car is running and received code 21...i just replace the vtec solenoid with a new one too so couldnt be that
Old Apr 26, 2002 | 08:41 AM
EP3_05's Avatar
How about the wiring to the Vtec solenoid??? Just a thought.
Old Apr 26, 2002 | 08:43 AM
dho311's Avatar
What kind of motor?
Old Apr 26, 2002 | 08:48 AM
Eg6_JDM's Avatar
Default Re: vtec? (dho311)
vtec will pull one time then i would get check light.....i've gotten a mechanic to rewire my harness and he has check it out but said its the ecu....
b16a 93 hatch
Old Apr 26, 2002 | 09:40 AM
pelotudo's Avatar
I had the same problem when I hooked up my VTEC light. Do you have any connections spliced off the solenoid wire? If so, try soddering the spliced wire to the original vtec wire, that should solve. If not, make sure all connections to and from the solenoid are secure and soddered.
jB
Old Apr 26, 2002 | 10:18 AM
Kamin's Avatar
b16a 93 hatch
replace the ecu with one you KNOW vtec works on. if the problem goes away. he was right.
Old Apr 26, 2002 | 10:27 AM
ricodemus's Avatar
I'm having a similar problem, but my vtec has never worked (but the solenoid is not bad). going through the helms manual points right to the ecu. I just think it's fishy that only the vtec activation could go "bad" in an electronic piece of equipment like the ecu. but what do I know...
swizz977
10
May 25, 2011 08:15 PM
fryguy190
Mar 23, 2008 07:27 PM
Pr0ject93hb
Sep 14, 2007 09:50 AM
demdem
Jun 8, 2006 07:53 PM
thangbui
Oct 23, 2005 08:05 AM
