Vortech emergency-Please help!!
Old Nov 10, 2002 | 11:08 PM
ThugLife52's Avatar
Default Vortech emergency-Please help!!
Two mechanics and I just finished installing a vortech aftercooled supercharger kit and a type R intake manifold on my 2000 civic si. After we were completly finished, we did the final checks; no fuel leaks, no vaccum leaks (as far as we could tell). When we tried to start the car it immediatly started to rev by itself and I had to shut it off before it reached the rev limiter. We spent an hour trying to figure out the problem but to no avail. Does anyone have any suggestions on what might cause this? Any help would be greatly appreciated.
Old Nov 10, 2002 | 11:24 PM
kinesistech's Avatar
Default Re: Vortech emergency-Please help!! (ThugLife52)
Let the engine breath without the stupidcharger to make sure its the engine. Then find the vaccum leak.
Old Nov 10, 2002 | 11:55 PM
Kamin's Avatar
Default Re: Vortech emergency-Please help!! (kinesistech)
yep disconnect the asscharger and find the vacuum leak. because you do have one.
Old Nov 11, 2002 | 07:43 AM
1bad_EF's Avatar
From: On a pile of junked Acuras and Hondas, WI, usa
Default Re: Vortech emergency-Please help!! (KAMiN)
check your throttle cable and look for vacuum leaks
see if you throttle plate is closed all the way at idle.
sounds like you forgot a vacuum line (brake booster, fuel regulator, check valve)
Skunk2DC2
Aug 11, 2012 12:30 PM
ITR.#1446
Dec 9, 2004 09:26 AM
Mike17
May 20, 2004 01:08 PM
ThugLife52
Nov 11, 2002 07:41 AM
HybridEkCivic
Oct 21, 2002 07:55 PM
