Valve Noises....
Old Jan 4, 2010 | 04:58 AM
S117A47's Avatar
Default Valve Noises....
Ok, so i have a 97 Civic LX 4speed Auto with about 154000 miles. Its my DD. SOHC D16Y7. Whenever its cold outside, especially in the morning, there is a loud tapping noise coming from the engine bay. Once it reaches normal operating temp, the noise dissipates. I always just figured it was valve lash. I adjusted my valves, and the noise was still there. Yes, i adjusted them while the car was cold.New valve cover gasket, spark plug seals, and gromets. So what is the issue? A helpful lad told me in another thread said my valves were burned (My apologies for commandeering that thread.) Thanks!
Old Jan 4, 2010 | 08:14 AM
S117A47's Avatar
Default Re: Valve Noises....
ttt
Old Jan 4, 2010 | 11:47 AM
S117A47's Avatar
Bump
Old Jan 4, 2010 | 12:48 PM
fv8s's Avatar
my friend has the same issue and did exactly what you did but still has a small tick/ knock noise. it could even be a bent valve. the only way to check it to pull the rockers and cam and remove the valves. its a lot of work but you will be able to actually figure out whats wrong
Old Jan 4, 2010 | 02:49 PM
S117A47's Avatar
Could it just be an unlubricated rocker am or valve that gets lubricated as the engine warms up?
Old Jan 6, 2010 | 04:12 AM
dognutz's Avatar
bump for anymore quesses for this guy.
Old Jan 6, 2010 | 07:20 AM
delsolproblems's Avatar
Burned or bent valves would make a noticeable impact on compression. Try borrowing a compression tester from a parts store.
Old Jan 6, 2010 | 07:21 AM
No
Old Jan 6, 2010 | 08:07 AM
shifty35's Avatar
I'd guess still valve lash. It's hard to get right, might want to try again.
Old Jan 6, 2010 | 11:44 AM
DA9 Bret's Avatar
Correct me if I'm wrong but injectors can also make a ticking noise as well, right? Something else to consider. Thats what I was told about my Isuzu Rodeo anyway. You can take the tip of a screwdriver and place the small end on the injector and listen to the handle and find which one is ticking the loudest and it would either need cleaned or replaced. the screwdriver acts like a stethoscope, unless you actually have one.
pityocamptes
26
Mar 25, 2016 10:23 AM
ArmaanOG
Apr 8, 2009 03:16 AM
Dav94Lx
Oct 9, 2007 07:53 PM
larsoch
Sep 28, 2006 08:30 PM
frank2660
May 7, 2006 06:17 PM
