VAFC, Vto OFF
Old Feb 23, 2004 | 06:18 PM
gamakichi77's Avatar
Default VAFC, Vto OFF
I got problem when i reconnect my VAFC to my ECU, PWO again. All of the wirings is correct. When engine is idle, i check my Vto is OFF on VAFC screen, but when i rev it till vtec engagement, vtec is engage.
Anybody here did faces this kind of problem?
thanks.
Old Feb 23, 2004 | 09:35 PM
boostn420's Avatar
Default Re: VAFC, Vto OFF (acidburns_di)
What the problem is, VTO means vtec out. Its only on when at the rpm you select to engage vtec and after. Even in at a stop. VTI is vtec in, when the computer wants to do it. Yours sounds like its working just fine.
Old Mar 2, 2004 | 05:43 PM
Default Re: VAFC, Vto OFF (boostn420)
Ok...i understand now. VTo means VAFC switch vtec and VTi when ECU switch vtec.
My cars running good.
Another question. What does it mean by Narrow Throttle and Wide Throttle?
Should i sets my Narrow Throttle same with Wide Throttle? ( in fuel enrichments percentage ).
Old Mar 2, 2004 | 06:23 PM
NC-B17A's Avatar
http://www.apexi-usa.com/produ...c.pdf
Old Mar 2, 2004 | 06:39 PM
Default Re: VAFC, Vto OFF (NC-B17A)
Thanks for your concern NC - B17A. But i do have this APEXi Manual already. Itt not answering my question. I'm just wondering what does it mean by Wide Throttle and Narrow Throttle. And should i sets both with the same percentage of fuel enrichment.
Old Mar 2, 2004 | 06:57 PM
MrTodd's Avatar
Well, if you read the manual he is referring you to, then you'd understand how the Narrow and Wide throttle functions work.
Old Mar 7, 2004 | 05:18 PM
NC-B17A's Avatar
Narrow is normal driving
Wide is hard throttle.
You should set them as your car needs. A dyno with a wideband O2 is the only way to tell the best settings for sure.
Old Mar 27, 2004 | 11:56 PM
lvbuckeye's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acidburns_di &raquo;</TD></TR><TR><TD CLASS="quote">Ok...i understand now. VTo means VAFC switch vtec and VTi when ECU switch vtec.
TAKE IT TO A SHOP TO GET IT TUNED.
it will cost you like 50 bucks, and your **** will run GOOD...
genetsang
Aug 20, 2003 01:54 PM
98R-1144
Nov 4, 2002 05:12 PM
EleanoR
Apr 17, 2002 06:06 PM
Wet Nudl
Feb 25, 2002 01:46 PM
