VAFC Apexi controller
What pisses me off about these i that the cheapest hook-up with an industry contact is right below $300, I know they retail in Japan for like $200! That sucks!
$300 is only a couple hundred away from Hondata.
It's worth the $300, especially when you have it tuned on the dyno. You motor will thank you as your can adjust the A/F to a stoic rate, your fuel economy improves, and you'll see gains throughout the entire powercurve. Oh, and yes, you can manipulate the VTEC crossover.
...Actually the base hondata system starts at just over $300...if you have it tuned...you can also adjust your timing ....unlike the vafc ....this will help solve alot of problems ....especially if your running high compression ....anyway if your in so cali and your interested ....hit me up
[Modified by allmotorgurl, 4:38 PM 6/7/2002]
yes you can ...if u have the button for the stage four...u need to get it dyno tuned...and after that you shouldnt need to change it again ...IM me if your interested and in so cal
I think its great controller, I installed it my self and took it to my local shop here in AZ and after they tuned I got a good 9.9 horsepower and a 7.8 torque gain from my crvtec motor. So I think its a verygood investment, well in my personal opinion also its the dopest looking vtec controller out there. Hope this helps.
Any of u guys use this controller before? What did u think? Where is the cheapest place to buy?
Thanks
Thanks
VAFC is just a little fuel only adjustment device. it sure give u some gain, but cant compare with hondata which fuel and ignition timing is adjusted.
WAFFLES
Jan 28, 2006 08:18 PM
pootie.teng
Jan 22, 2004 11:40 AM
