Urgent Electical Problem. help needed.
Old Sep 15, 2009 | 09:54 PM
thanh4o8's Avatar
Default Urgent Electical Problem. help needed.
Today i decided to take off my piping to get it done.
CEL went on.i left the cat on and it hung and started
scraping the ground. Drove home and on my way, my
speedo decides to stop working. then out of no where
my car dies when i hit the brakes at a red light. tried to
push start. had to feather the throttle to keep it alive.
couldnt drive AT ALL. friend came to jump start my car.
drove fine for a bit then it happended again. Drove home
and parked it. Took off the cat and cut off the O2 sensor
for now. Where does the wires to the second o2 sensor go?
Anyone have anything to say? I think the cat pulled on the
secondary o2 and messed up the harness or somthing.
threw two codes : 20-Electrical load detector
65 Secondary oxygen sensor heater
$25 Paypal if you figure out the problem.
Old Sep 16, 2009 | 08:55 AM
abelkayn's Avatar
Default Re: Urgent Electical Problem. help needed.
Im guessing this happened in your sedan, first off, if you got a code for you ELD (electronic load detector) you had a short and casused it to burn out. its located in your fuse box, the sensor with a brass looking bar going through it. second off i think the short might have been the second o2 wiring. if you want to get to it, its located behind stereo and ashtray on floor. fix the short first then replace the ELD and o2. good luck, pm me if you need more info.
Old Sep 17, 2009 | 07:47 PM
Former User's Avatar
I think that if you check 7.5A fuse #15 under the dash, it is blown. If so, you can learn how to fix the problem by reading this TSB.
thanh4o8
Sep 16, 2009 09:46 PM
yairsaenz83
30
Jan 5, 2008 01:26 PM
b 1 6 e g
Feb 27, 2006 11:29 AM
Civicse
Feb 13, 2006 12:33 PM
mechanix619
Mar 25, 2005 04:51 PM
