Uberdata???
anyone hear of this new system called uberdata? supposed to be just as good as hondata and like half the price.... i was wondering if anyone knows someone or has used this system personally.. and how it exactly works .. laptop, controller etc...??
This has got to be a joke! If not, Click Here, read and then if you still have any Uberdata questions, ask them there. Good Luck. I love Uberdata
Phil
Phil
It's not as quick for me to tune, but it's pretty comparable in terms of final results if you spend enough time on the fine tuning. The Hondata calibrations I do usually come out more comprehensive than the Uberdata stuff b/c I run into time constraints.
Both allow you to independently change the fuel and ignition timing values on a 15x20 Uberdata (13x20 Hondata) load-rpm table. You get a fuel and ignition timing basemap for the LO cam and HI cam. The HI cam basemaps are used for VTEC motors. You also get access to the VTEC crossover rpm, idle speed, rev limiter, injector correction, accel pump, closed loop disable, and a few other minor things.
I like the Hondata datalogging much better as well as the ability to make changes on-the-fly. Those two features make it quicker and easier to tune Hondata.
