turbo problems....=(
Old Feb 3, 2003 | 05:31 PM
SoCaLeK's Avatar
Default turbo problems....=(
okay heres the deal. i bought a used turbo from this guy. he installed it and everything. BUt my car has been smoking ever since then. I know for sure that its not the rings or the valve stem seals or the head gasket. im sure its the turbo. I got a fuel regulator and set it to stock cuz i was told that it was runing a bit rich. still smoking and even when im not boostin. NOw i wanna know what could be on the turbo thats making it smoke? THe installation was a clean job. please someone help!!
Old Feb 3, 2003 | 05:34 PM
Kamin's Avatar
Default Re: turbo problems....=( (SoCaLeK)
used turbo?
possibly the oil seals
http://www.cheapturbo.com rebuilds them for a couple hundred bucks. but before you go spending all that money remove the turbo, bolt up the stock header and see if its still smoking.
does the turbo boost ok?
Old Feb 3, 2003 | 05:49 PM
SoCaLeK's Avatar
the turbo boosts really good even at 5 lbs. but yeah thats what i was thinking too the seals.
Old Feb 3, 2003 | 05:51 PM
Kamin's Avatar
do you know if it burns more oil under boost?
i have a feeling its the seals.
Old Feb 3, 2003 | 08:41 PM
SoCaLeK's Avatar
Default Re: turbo problems....=( (Kamin)
im gonna check the oil tomorrow. i think its the seals as well. will let you guys know man.
Old Feb 3, 2003 | 10:26 PM
tominos's Avatar
yea, rebuild it.
Old Feb 4, 2003 | 06:14 AM
SoCaLeK's Avatar
Default Re: turbo problems....=( (tominos)
out of curiousity what needs to be rebuild when rebuilding one?
Old Feb 4, 2003 | 07:37 AM
SoCaLeK's Avatar
oil level seems to be fine. I didnt really boost alot because i was afraid something else might go wrong.
Old Feb 4, 2003 | 10:13 AM
SoCaLeK's Avatar
okay i have found my problem
seems like there is oil leaking from the turbo. after i ran it. i oppenned up the hood and i saw oil around the turbo.
Old Feb 4, 2003 | 10:51 AM
Blaze45's Avatar
Brrraaaap!
yeah its your seals on your turbo, you gonna have to rebuild it.
Good Luck
Blaze
Old Feb 4, 2003 | 11:17 AM
Kamin's Avatar
Default Re: turbo problems....=( (Blaze45)
well it could be somthing simple like a seal on the oil feed or return line
i still think its the seals on the actual compressor because i dont think the feed/return lines will impact exhaust smoke.
you might have 2 leaks.
see this is why i will NEVER buy a used turbo.
Old Feb 4, 2003 | 12:32 PM
squirrel's Avatar
I think that as long as it's not a ball bearing turbo, you can rebuild it.
www.turboxpress sells rebuild kits. I don't think they're listed on the site, but email them about it. The sites+ a little cheesey, but they have good prices.
luv2boost
Jul 6, 2007 05:01 AM
sykotic
Mar 15, 2005 03:05 PM
RICE POLICE SIP
Nov 6, 2002 01:30 AM
JV
Jan 23, 2002 01:23 PM
