Tuning a V-AFC
Old Apr 14, 2002 | 09:55 PM
SCsol's Avatar
Default Tuning a V-AFC
hello there guys i have a mugen ECU. IT take way too much fuel when just crusing. I know they run a closed loop. So with the V-AFC how can i lean it out without killing performance. I know theres 2 setting for throttle settings (wide, Narrow). If i remove fuel out of the Narrow throttle will that fix it. And setting the Narrow throttle in the [TH-Point] for eg if Narr. is set to %20 would the [Narr.Thr] be used from %0-20, or is it from %20 to what the high point is set to (%).
So if TH points are set to %20 for low and %50 for high what % would the Narrow throttle be used %0-20 or %20-%50 thanks again
Old Apr 15, 2002 | 07:11 AM
SCsol's Avatar
Default Re: Tuning a V-AFC (lowsol)
no one here us a V-AFC please help
Old Apr 15, 2002 | 07:42 AM
SCsol's Avatar
TTT
Old Apr 15, 2002 | 07:57 AM
SCsol's Avatar
Default Re: Tuning a V-AFC (C5_ALLMOTOR)
4in 4 out i thought is should be 6in and 6out and what about setting the high and low throttle setting
Old Apr 15, 2002 | 08:18 AM
BoM's Avatar
BoM
what settings do u change when on the dyno?
wide throttle ?
Old Apr 15, 2002 | 09:05 AM
Malice's Avatar
New User
4 in 4 out?!! mine are ay 6&6. oh crap!
but when i tried to mess with it the other night, i changed it to 4 and the car died. whats up with that?
Old Apr 15, 2002 | 09:19 AM
93LSVTEC's Avatar
Default Re: Tuning a V-AFC (MaliceGSR)
You can't change sensor input settings while the car is running. I'm running 6 in 6 out like the manual says. I know it works on 6..6 because if I drop my fuel way low at idle I can make the car want to cut off...
Old Apr 16, 2002 | 05:59 AM
SCsol's Avatar
ok guys what about the low and hight throttle settings if there set to %10 low and %50 high does that mean narrow throttle is better %0-10 or between %10-50 please guys i need to know this one thanks
Old Apr 16, 2002 | 07:07 AM
Greyout's Avatar
at those settings, the VAFC will follow the low throttle correction up until 10%, and use the high throttle after 50%. in between, it makes an average between your two curves.
Old Apr 16, 2002 | 10:07 PM
SCsol's Avatar
Default Re: Tuning a V-AFC (JDM LUDE)
JDM lude thanks
sir2sol
Apr 16, 2006 05:46 PM
98R-1144
Jan 2, 2003 07:25 PM
CPR
Oct 2, 2002 10:37 AM
IgniteTeg
Aug 9, 2002 07:25 PM
1320Motorsports
Nov 22, 2001 06:29 AM
