help with vafc
Old Apr 10, 2006 | 08:09 AM
sir2sol's Avatar
Default help with vafc
just installed an apexi vafc on my b16a, only problem is that the car won't stay running. and when it does, everytime i step on the throttle the car dies. i know it has something to do with my throttle setting, but not quite sure whats going on here. anyone have any thoughts?
Old Apr 11, 2006 | 06:54 PM
mastarolla's Avatar
Default Re: help with vafc (sir2sol)
throttle settings only change the fuel map in the given throttle % and interpolates between....set at 10 for low and 50-60 for WOT to start.
My guess is that you need to dial in the cylinder numbers, let the VAFC learn the closed and open throttle through initialization and you should be good from there.
Old Apr 11, 2006 | 07:23 PM
boostd92's Avatar
I'd bet he has one of the basic settings not set.. like cyl or AFM type.
Old Apr 11, 2006 | 10:24 PM
sir2sol's Avatar
Default Re: help with vafc (mastarolla)
cool thanks for the heads up
Old Apr 16, 2006 | 05:46 PM
The Clash's Avatar
Even if you get the car running right after installing the VAFC... you're just pissing in the wind by changing the settings unless you have a true wideband O2 or you're dyno tuning. Chances are you're hurting more than helping - tune it right!
smkngsr
Apr 11, 2005 05:58 AM
HondaJon
Jul 26, 2004 05:42 PM
gamakichi77
Oct 26, 2003 11:16 PM
Art Vandeleigh
Oct 26, 2002 09:14 PM
Asahi
Jun 1, 2002 04:52 PM
