Tranny Problems, Experts wanted
Old Aug 11, 2003 | 10:11 PM
EG6owner-T's Avatar
Default Tranny Problems, Experts wanted
ok straight to the point.
shifting to 2nd and 4th is a shorter throw than before a longblock swap.
reverse a little bit different.
1st, 3rd, and 5th feels normal to me.
Could this be that the shift linkage is bent. Let me know. Thanks.
Old Aug 12, 2003 | 09:51 PM
EG6owner-T's Avatar
Default Re: Tranny Problems, Experts wanted (EG6owner)
help?
Old Aug 13, 2003 | 12:43 AM
Kamin's Avatar
if you dont have any problems getting it into gear or keeping it there i dont see much of a problem.
Old Aug 13, 2003 | 09:55 PM
EG6owner-T's Avatar
Default Re: Tranny Problems, Experts wanted (Kamin)
it is a shorter throw with stock parts, yes its hard to get into 2nd and 4th its not the same
ima change the shifter this weekend hopefully that solves it.
Old Aug 14, 2003 | 02:59 PM
smokey2.0's Avatar
if the linkage is not bendt, check the rod that comes out of the tranny case. if it's bend't, the gears won't stay in place!
Old Aug 15, 2003 | 02:29 AM
EG6owner-T's Avatar
Default Re: Tranny Problems, Experts wanted (smokey2.0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokey2.0 &raquo;</TD></TR><TR><TD CLASS="quote">if the linkage is not bendt, check the rod that comes out of the tranny case. if it's bend't, the gears won't stay in place!</TD></TR></TABLE>
check the rod if its bents? 1st, 3rd, 5th stays perfect others have a little problem
Old Aug 15, 2003 | 03:43 PM
smokey2.0's Avatar
change the shifter and see if that helps, one time i installed a shifter backwards. i never took the car on the road to see if it would still work, let me know if changing the shifter has any effect on 2/4 gears!
Old Aug 15, 2003 | 10:19 PM
EG6owner-T's Avatar
ok yes i changed the shifter now everything is find
Rancidracer86
Dec 18, 2008 06:57 AM
Timmyflys
Aug 13, 2007 03:34 PM
TylerC
Nov 16, 2005 05:29 AM
rac3rb0i
Nov 30, 2004 11:02 AM
DC24jooo
Jul 6, 2004 08:46 PM
