tranny problem: shift rod floats around in gear
Old Oct 9, 2003 | 09:03 PM
Shane54's Avatar
Default tranny problem: shift rod floats around in gear
The car is a 95 Integra RS and in any gear the shift rod moves left and right like there is no linkage.
thanks in advance for the help.
Old Oct 9, 2003 | 09:09 PM
Mochanic's Avatar
Default Re: tranny problem: shift rod floats around in gear (Shane54)
so it doesnt shift at all?
check to make sure the roll pin is still there where the shift rod hooks up to the tranny... its the one that should have a boot around it.
Old Oct 10, 2003 | 06:42 AM
TimoneX's Avatar
New User
Default Re: tranny problem: shift rod floats around in gear (Mochanic)
Check the shift linkage. Directly behind the shift lever there's a bushing that the extension rod rides in. If it's become torn or otherwise damaged the extension rod will be allowed to move easily side to side w/o rotating the shift rod at the tranny.
Old Oct 10, 2003 | 11:50 PM
Shane54's Avatar
Default Re: tranny problem: shift rod floats around in gear (TimoneX)
found the problem, thanks for the help
Old Oct 10, 2003 | 11:54 PM
TimoneX's Avatar
New User
So what's the problem? Or is it too embarrasing?
Old Oct 11, 2003 | 09:50 AM
Mista Bone's Avatar
D Tranny Guru
shifter bushing on bottom of shifter.
The ONLY reason I went to a short shifter. Got a nice Edelbrock unit, has bearings instead of rubber O rings.
Old Oct 11, 2003 | 08:53 PM
Mochanic's Avatar
next time inform us that you @$&@$! with it and then the problem started happening... the way you make it sound is that it just started all of the sudden by itself.
Ninety3 Integra
Transmission & Drivetrain
17
Apr 13, 2014 05:31 AM
Trian
Jun 19, 2006 02:33 PM
BDogggUT34
38
Apr 11, 2005 02:19 PM
SOHC_Brian
11
Nov 19, 2003 07:42 PM
WONG FRIED RICE
Apr 17, 2003 09:05 AM
