TPS problem
Old Dec 18, 2005 | 10:22 PM
VAturbob20's Avatar
Default TPS problem
Hondata s200 p72 ecu,
TPS reads at a constant 26%
tps sensor is good, also tried another tps sensor
tps wiring is good, 3 wires were ran just to be sure, correctly following wiring diagram
something must be causing it to default 26%
wiring/sensor/ correct
anyone?
Old Dec 19, 2005 | 11:45 AM
VAturbob20's Avatar
Default Re: TPS problem (VAturbob20)
up
Old Dec 19, 2005 | 03:04 PM
Dogginator's Avatar
Daisy... Daisy...
Did you somehow switch the TPS and MAP sensor plugs on the throttle body?
Old Dec 19, 2005 | 03:19 PM
VAturbob20's Avatar
Default Re: TPS problem (Dogginator)
nope
Old Dec 19, 2005 | 03:22 PM
Dogginator's Avatar
Daisy... Daisy...
That would have been the easy fix. Have you measured the voltage at the TPS connector and the ECU inputs?
Old Dec 19, 2005 | 04:45 PM
VAturbob20's Avatar
yes i have,
Old Dec 19, 2005 | 04:55 PM
Dogginator's Avatar
Daisy... Daisy...
If the voltage is changing at both locations (TPS and ECU), your ECU is most likely faulty. I'm not familiar with the Hondata programming. Could a faulty .bin file cause the TPS to be ignored?
Old Dec 19, 2005 | 07:02 PM
VAturbob20's Avatar
i'm not sure, but i just checked the voltage again, 0-5volts as you increase, thats not it,
i'm wondering if something else is causing it to default 26%
Old Dec 20, 2005 | 03:55 AM
Dogginator's Avatar
Daisy... Daisy...
Was this 0-5 volts was also observed at the ECU plug? I'm just trying to rule out a wiring issue. Has the ECU or engine harness been modified in any way?
Old Dec 20, 2005 | 02:33 PM
VAturbob20's Avatar
a 3bar was added, the tps is now straight wired back to the ecu, correctly,
ecu has a s200 hooked up to it.
i received the car not running so i dont know if it had the tps issue or not
Old Dec 20, 2005 | 04:10 PM
Combustion Contraption's Avatar
26% is a default value yes. It sounds like you have the 5 volt reference and the varying voltage signal wire switched. Check voltage at the ECU not at the connector.
Old Dec 25, 2005 | 04:55 PM
VAturbob20's Avatar
Default Re: (LsVtec92Hatch)
checked at the ecu, the voltage is correct , .50 at closed and 4.50 at WOT, i think it might be in some sort of limp mode causing it to stay at 26% tps
Old Dec 25, 2005 | 06:46 PM
nolimits's Avatar
Default Re: (VAturbob20)
Make sure the pin is fully seated in the connector (remove the connector and look to see if the pin is flush like the others). If that's ok, look to the Hondata.
Old Dec 27, 2005 | 04:13 PM
VAturbob20's Avatar
Default Re: (nolimits)
thats not it
Old Dec 28, 2005 | 05:55 PM
VAturbob20's Avatar
thats not it
boostedblue23
Engine Management and Tuning
Apr 3, 2018 07:59 AM
SiTR
May 7, 2008 02:05 AM
hondamama7894
Jul 28, 2005 09:41 PM
DanishR
May 14, 2005 11:05 AM
wade
May 31, 2004 12:32 AM
