Torn/Stripped Engine Mount Studs
Old Aug 18, 2004 | 04:14 PM
GapxGuy's Avatar
Sushi Buffet Champion
Default Torn/Stripped Engine Mount Studs
I have an engine mount in my EK which has been ripped off the chasis by the tranny.
Pictured below is #8.
One stud has fallen off which the remaining one is a loose tooth.
My question is what to do? Weld? Retap? BTW, this is causing extreme vibration during acceleration. TIA.
Old Aug 18, 2004 | 11:48 PM
GapxGuy's Avatar
Default Re: Torn/Stripped Engine Mount Studs (GapxGuy)
ttt
Old Aug 24, 2004 | 09:41 PM
GapxGuy's Avatar
The front bolt is still good, the rear is busted. What I did today is got the rear of the mount welded to the chasis. This definitely was the problem of the shaking, but it still shakes at fast acceleration or high speed.
Should I go back to the welder and tell him to put another chunk of weld on the mount? Or could it be a diffferent mount?
mclasser
Aug 4, 2015 12:37 PM
aaronhume
Mar 23, 2007 09:16 PM
GapxGuy
Welding / Fabrication
Aug 25, 2004 07:39 AM
GapxGuy
Aug 24, 2004 09:41 PM
sysconx
Oct 6, 2003 03:50 AM
