Replacing rear engine mount
Old Aug 3, 2015 | 05:50 PM
mclasser's Avatar
Default Replacing rear engine mount
I have an 02 4-cyl. How difficult is it to replace the rear engine mount on my own? YouTube has some videos for 5th gen Accords but not mine. I've done the front mount before which was pretty simple. Can anyone point me to a write up (if there is one)?
Thanks!
Old Aug 4, 2015 | 12:37 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Replacing rear engine mount
Disconnect the front stopper mount. Removing the through bolt should be enough.
Remove nut on the top of the rear mount.
Disconnect vacuum line to the rear mount.
Unbolt four bolts holding the rear mount to the rear beam.
Use a jack to gently rotate the engine forward. Raising under the oil pan(with a block of wood) usually allows enough room to slide/rotate mount out.
Hardest part is getting the mount out/in from around the brackets/exhaust/etc.
FWIW, if the front 'stopper' mount is broken, it is most likely due to the rear mount(actual) no longer functioning properly.
JWHATCH23
Dec 20, 2006 08:13 PM
Greg456
Apr 8, 2004 09:49 PM
sysconx
Oct 6, 2003 03:50 AM
CristalCleanCivic 97 EX
Aug 8, 2003 10:39 AM
