Too Lean in fuel system!!!
Old Oct 28, 2002 | 02:32 PM
CIVIX's Avatar
Default Too Lean in fuel system!!!
What does running too lean mean? That is the code(45 Honda Civic 96-98) that my ecu is throwing out what does that mean? What could it be? Any help would be appreciated THANX
Old Oct 28, 2002 | 02:43 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: Too Lean in fuel system!!! (CIVIX)
nto enough fuel per parts of air...
Old Oct 28, 2002 | 03:30 PM
texan's Avatar
Default Re: Too Lean in fuel system!!! (dLo GSR)
clogged fuel filter, dying fuel pump, clogged or dead injector(s). Those are the most likely culprits, the first thing you ned to do is check the plugs for signs of lean running and if they all look the same check the fuel pressure. It could also be your 02 sensor dying, which can show up as either rich or lean running, but generally that throws a specific code for the sensor itself.
Old Oct 28, 2002 | 03:32 PM
Chiovnidca's Avatar
The first thing I check is fuel presure. BTW, If it's a 96 or 97 and has less than 150,000 miles it is covered by the emission extension warranty.
Old Oct 28, 2002 | 07:53 PM
CIVIX's Avatar
Default Re: Too Lean in fuel system!!! (Chiovnidca)
What is the emission extension warranty?
Old Oct 28, 2002 | 08:59 PM
kinesistech's Avatar
I believe it says that regardless of manf. warrenty, emissions related devices are covered for 5 years. Some parts are 7 but just a few. If you try it be ready to pay when its not covered. The book says check the vaccum to the map sensor, and fuel regulator. An exhaust leak can also do it.
Old Oct 29, 2002 | 03:10 AM
Chiovnidca's Avatar
On some 95 and most 96 and 97 Hondas the emission warranty was extended to 150,000 miles or 14 years. There is a service bullitin on it. #98-081.
weirdone86
Sep 14, 2006 07:35 AM
D@nnY
Jan 11, 2004 07:57 AM
2000CX
Aug 14, 2003 05:15 PM
2oh6civic
Mar 30, 2003 07:26 AM
IwanAturBo
Mar 16, 2003 06:53 PM
