smelling fuel...
Old Aug 14, 2003 | 01:58 PM
2000CX's Avatar
Default smelling fuel...
ok...so i went through a period of running super rich due to a bad IAT sensor. replaced that and now i am back to my good old secondary o2 code (65)...but the car is running fine. anyway...over the past couple days i have noticed a slight smell of fuel at idle from under the hood. could i have ruined anything in the fuel system from running so rich? i have new plugs just waiting to get put in...but i kinda wanted to work the bugs out first before i throw them in.
Old Aug 14, 2003 | 02:39 PM
allwheelerman's Avatar
Default Re: smelling fuel... (2000CX)
if you smell fuel i would check all the fuel lines
Old Aug 14, 2003 | 03:18 PM
2000CX's Avatar
Default Re: smelling fuel... (allwheelerman)
i've looked them over and found no leaks...either at idle or when its shut down.
Old Aug 14, 2003 | 03:26 PM
b20ek's Avatar
Well without seeing your car in person its gonna be hard for anyone to diagnose. First off if your throwing a cel for o2 then your car is running in loop mode so its still gonna be running very rich. You might be smelling unburned fuel in your exhaust. If not then double check all your fuel lines and around your injectors.
Old Aug 14, 2003 | 03:53 PM
2000CX's Avatar
Default Re: smelling fuel... (b20ek)
how bad can this be for the motor? the throttle response has been real chunky...if i'm just tapping on it it feels like it doesn't know how to react...either it all the way on or idle...if that makes any sense?!?!
Old Aug 14, 2003 | 05:15 PM
b20ek's Avatar
Well its never good to run the engine when you have something wrong with it. Driving it in loop mode might cause a little carbon build up in the combustion area from running so rich and it could cause your catylictic converter to fail. That's about it.
Circaskaterr
28
Jan 28, 2016 09:31 PM
DawgC2
Mar 10, 2012 12:11 PM
LowTec MOHawk
14
Oct 5, 2007 10:49 AM
CIVIX
Oct 29, 2002 03:10 AM
Litoman
Aug 15, 2002 07:53 PM
