Timming on 99 D16Y8
Old Dec 10, 2006 | 01:35 PM
Fugispeed's Avatar
Default Timming on 99 D16Y8
Have timming marks lined up but when I put timming light on, marks on pulley are not 7 degrees retarded was told I have to jump a wire or pull a fuse if that is correct which wire to jump or what fuse to pull
Old Dec 14, 2006 | 06:12 PM
sexyrex's Avatar
Default Re: Timming on 99 D16Y8 (Fugispeed)
set base timing and than check timing, i think its 16-18 degrees BDC.
Old Dec 15, 2006 | 08:20 AM
Bense's Avatar
Default Re: Timming on 99 D16Y8 (sexyrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sexyrex &raquo;</TD></TR><TR><TD CLASS="quote">set base timing and than check timing, i think its 16-18 degrees BDC.</TD></TR></TABLE>
16 +/- 2 for d16z6
12 +/- 2 for d16y8
Old Dec 15, 2006 | 12:58 PM
JimBlake's Avatar
So I'm guessing this was your real question...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fugispeed &raquo;</TD></TR><TR><TD CLASS="quote">... was told I have to jump a wire or pull a fuse if that is correct which wire to jump or what fuse to pull </TD></TR></TABLE>
I don't have a D16, but for Hondas in general, you have to have the engine warmed up, & jumper the SCS connector (same plug as what you use to read CEL error codes).
When you jumper that connector (with a paperclip) it tells the ECU to quit making it's constant adjustments to spark timing.
If you have to change the spark timing, you should reset your ECU after you're done. Then start the engine without touching the gas pedal, & let it idle for something like 10 minutes without touching anything.
ewilliams1990
13
Aug 17, 2013 06:09 PM
DC_RaceR
Aug 24, 2006 06:45 PM
Jonovision
Sep 30, 2005 07:16 PM
redpeppers
Jul 25, 2005 09:39 PM
thatbluecrx
Feb 27, 2005 10:15 AM
