advancing/retarding dizzy timing on b16..?
Old Feb 18, 2005 | 11:14 AM
thatbluecrx's Avatar
Default advancing/retarding dizzy timing on b16..?
i read in my chiltons book that u have to short a wire under the passenger side dash before you change the timing... when i short the wire the car runs like **** very sputtery.. is this needed to do when changing the timing?...
also.. should i be ******* with the timing? its stock with bolt ons... vtec feels like it makes it lean out for a little from when it kicks(5100) to about 6k
any feelings on this?
basically wondering where i should set it for optimal upper rpm pull..
Old Feb 18, 2005 | 02:50 PM
t0p_sh0tta's Avatar
Default Re: advancing/retarding dizzy timing on b16..? (thatbluecrx)
How the hell does it feel like it leans out?
Old Feb 27, 2005 | 08:47 AM
mongoliandonuts's Avatar
you put the wire to reset the ecu so it doesnt try to adjust itself. soo kept the jumper wire in there change the timing maybe turn it off then on then off and pull the jumper wire. it would lean out a little depending on how much you advance/retard the timing.
Old Feb 27, 2005 | 10:15 AM
Default Re: advancing/retarding dizzy timing on b16..? (mongoliandonuts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta &raquo;</TD></TR><TR><TD CLASS="quote">How the hell does it feel like it leans out?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mongoliandonuts &raquo;</TD></TR><TR><TD CLASS="quote">it would lean out a little depending on how much you advance/retard the timing.</TD></TR></TABLE>
thats how!
1994accord
Jul 26, 2013 11:01 PM
76 camaro car
May 21, 2011 10:25 AM
DC_RaceR
Aug 24, 2006 06:45 PM
fe519
Nov 23, 2002 03:55 PM
Etylorcen
May 26, 2002 07:30 PM
