timing mark continuously advancing
So I just got my GS-R motor together last night, and when I went to set the timing, I noticed something really strange. When I put the timing light on it, I couldn't get the marks to stay consistant. Yes I had jumped out the service check connector. The gun was set at 0 degrees, but looking at the crank, the mark seemed to be moving in a complete circle. The only way I could keep it in one spot was to consistantly advance the timing **** on the gun. But then I run out of **** so it just keeps moving. Wierd. Let me know if any of you have any ideas.
is your inducitve pickup working correctly on the cyl1 the one on the timing belt side.
i think your pickup on the gun is causing this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type-GS-R-Turbo »</TD></TR><TR><TD CLASS="quote">Actually, it was none of the above. The Crank pulley bolt and keyway somehow came out and the pulley wasn't spinning as fast as the crank.
ooops.</TD></TR></TABLE>
No damage???
No damage???
no damage. I had just got it started for the first time and it had only ran for about 2 minutes when I tried to set the timing. This is possibly the dumbest thread I've ever started. heh.
