no timing marks?
i just went out to check my timing and i couldn't see any timing marks. it's dark out too. the weird thing is that a few weeks ago when i put in a new distributor the timing marks were visible. any ideas?
r u try n to check the timing with a timing light? the lines should show up on the crank pully. maybe the pulley is dirty and its covering up the lines. turn the motor to TDC and take a cloth and clean the crank pulley, then put the timing light on it.
u r using a stock crank pulley right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 »</TD></TR><TR><TD CLASS="quote">r u try n to check the timing with a timing light? the lines should show up on the crank pully. maybe the pulley is dirty and its covering up the lines. turn the motor to TDC and take a cloth and clean the crank pulley, then put the timing light on it.
u r using a stock crank pulley right?</TD></TR></TABLE>
yeah i have a timing light i am using. it's weird that i could see the marks a few weeks earlier..i'm sorry but what's TDC? it might be dirty cause i took a road trip the other day. and yes i am on a stock crank pulley
dizzy from passenger side:
34
12
TDC is when u rotate the crank so that piston number 1 is at the top of the cylinder. when its at the top of the cylinder, the single white line on the pulley will line up with the pointer on the timing belt cover
34
12
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 »</TD></TR><TR><TD CLASS="quote">dizzy from passenger side:
34
12
btw..is that the same on all integra dizzy?
34
12
i'm not sure...i was turning the dizzy to fix the timing on the pulley. it might of been the crank tho cause it was throwing a crank sensor error a few days ago...maybe this fixed it cause it's not throwing a code anymore
LoGaN-VanG
13
Sep 27, 2011 05:27 PM
wantmorepower
Apr 16, 2003 09:52 PM
wantmorepower
Apr 15, 2003 08:07 PM
