timing mark continuously advancing
Old Dec 28, 2004 | 06:16 AM
Type-GS-R-Turbo's Avatar
Default timing mark continuously advancing
So I just got my GS-R motor together last night, and when I went to set the timing, I noticed something really strange. When I put the timing light on it, I couldn't get the marks to stay consistant. Yes I had jumped out the service check connector. The gun was set at 0 degrees, but looking at the crank, the mark seemed to be moving in a complete circle. The only way I could keep it in one spot was to consistantly advance the timing **** on the gun. But then I run out of **** so it just keeps moving. Wierd. Let me know if any of you have any ideas.
Old Dec 28, 2004 | 12:15 PM
b18bturbo's Avatar
Default Re: timing mark continuously advancing (Type-GS-R-Turbo)
is your inducitve pickup working correctly on the cyl1 the one on the timing belt side.
i think your pickup on the gun is causing this.
Old Dec 28, 2004 | 04:02 PM
civic-4-ges's Avatar
Default Re: timing mark continuously advancing (b18bturbo)
Making sure your car is warm?
Old Dec 29, 2004 | 05:07 AM
Actually, it was none of the above. The Crank pulley bolt and keyway somehow came out and the pulley wasn't spinning as fast as the crank.
ooops.
Old Dec 29, 2004 | 06:34 AM
Default Re: (Type-GS-R-Turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type-GS-R-Turbo &raquo;</TD></TR><TR><TD CLASS="quote">Actually, it was none of the above. The Crank pulley bolt and keyway somehow came out and the pulley wasn't spinning as fast as the crank.
ooops.</TD></TR></TABLE>
No damage???
Old Dec 29, 2004 | 09:55 PM
PrettyLude's Avatar
wow
Old Dec 31, 2004 | 05:40 AM
no damage. I had just got it started for the first time and it had only ran for about 2 minutes when I tried to set the timing. This is possibly the dumbest thread I've ever started. heh.
Old Dec 31, 2004 | 05:43 AM
Glad to hear nothing was damaged.
And there have been much much worse threads than this here on H-T!
marecco
Sep 7, 2007 01:12 PM
LoseRPunKx182
Aug 6, 2005 09:36 PM
IWearMyKswiss
Dec 16, 2004 07:55 PM
civbeater90
Nov 16, 2002 12:46 PM
