thrust bearings going out?
Old Sep 23, 2007 | 09:32 PM
  #26
GSaura's Avatar
Default Re: (slowteg90)
Because the noise gets louder at idle with the A/C on, I'm thinking that it might be load dependent. Does it knock when the car is moving and in gear? Louder when you goose it?
From my experience, throwout bearings make more of a squeaky noise when they go bad. If it were a thrust bearing problem, you'd hear it regardless of rpm and clutch engagement.
Old Sep 24, 2007 | 03:16 AM
  #27
slowteg90's Avatar
Default Re: (GSaura)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSaura &raquo;</TD></TR><TR><TD CLASS="quote"> If it were a thrust bearing problem, you'd hear it regardless of rpm and clutch engagement.</TD></TR></TABLE>
Really? I wasn't aware of that.
My clutch is pretty damn squeeky when its depressed.. I was thinking that was pretty normal though, my last honda did that too.
I can hear it just a little w/o the clutch depressed. If I bring the rpms up past say 1500? I will not hear the sound anymore, reguardless of weither the clutch is depressed or not.
Thanks for your info, hopefully I can narrow this noise down.
Old Sep 27, 2007 | 04:07 AM
  #28
slowteg90's Avatar
Old Sep 28, 2007 | 09:02 AM
  #29
slowteg90's Avatar
Old Sep 29, 2007 | 04:39 AM
  #30
slowteg90's Avatar
bump
Old Sep 30, 2007 | 01:26 PM
  #31
slowteg90's Avatar
bump 4 more opinions
Old Oct 2, 2007 | 06:57 AM
  #32
slowteg90's Avatar
Old Oct 2, 2007 | 06:59 AM
  #33
ForceFed Motorsports's Avatar
Do you even PLEBE R8?
You rip that tranny out of there yet to inspect?
Old Oct 2, 2007 | 11:05 AM
  #34
slowteg90's Avatar
Default Re: (ForceFed_Motorsports)
As much as I would love to, its my DD, so im still trying to diagnose a little further... As of now, im thinking the noise is deff from the throwout bearing, but im also pretty sure the thrust bearing are worn also, letting the crankshaft move when there is a load (A/C) on it, therefore moving the throw out bearing out of alignment...
any opinions?
Old Oct 2, 2007 | 11:21 AM
  #35
Well honestly at this point, if you have to replace any of the common failure bearings and have to remove the tranny you might as well do all of them. Normally im the type that doesnt throw parts at something to fix it, i promote proper diag but in a situation like that I would recommend replacing every bearing possible while the tranny is out.
Old Oct 2, 2007 | 01:32 PM
  #36
slowteg90's Avatar
Yeh. Im looking into a new(er) GSR swap w/ tranny.. I need a quick fix seeing as its my daily. I can swap the motor in a day, then have the spare GSR motor/tranny to build up, I was planning on that even before this even started happening. A few ppl have offered me very good deals on complete swaps, still in car to insure perfect running condition, for less that it would cost me to do a complete rebuild.
however, I would still like to know if anyone else has had this problem, its kind of annoying that I cannot seem to single out the problem... I guess that will happen when I have time to rip it apart
slowteg90
Oct 2, 2007 06:58 AM
numotive
Sep 11, 2005 10:31 PM
Full Race A6
Sep 7, 2004 02:12 PM
SSBlueDC2
Oct 24, 2003 02:25 PM
dubsee
11
Mar 29, 2003 09:42 AM
