Throttle Body Help
Old Nov 19, 2002 | 03:39 PM
dubnine's Avatar
Default Throttle Body Help
95 Gsr Throttle Body on an obd 2 car, what needs to be done to make it work? Bypass the fast idle thing, correct? How do i do that?
Old Nov 20, 2002 | 07:14 AM
dubnine's Avatar
Default Re: Throttle Body Help (dubnine)
ttt
Old Nov 20, 2002 | 10:58 AM
JHill's Avatar
To do a bypass, you need to make a block off plate for the bottom of the tb.
Jim
Old Nov 20, 2002 | 03:36 PM
Xsi's Avatar
Xsi
I had a similar question.
So you just make a block off plate and block off the spigot on the bottom?
And what about the coolant on a B16A1 TB, is it safe to do this?
So, just join the two hoses and have the coolant flowing straight from the spigot on the head to the IACV?
Old Nov 20, 2002 | 03:51 PM
dubnine's Avatar
Default Re: Throttle Body Help (Xsi)
What year B16 throttle body is that? I think all you have to do on those is just plug the spigots up. 95 GSR throttle bodies have a Idle Controll Thing underneath the throttle body that needs to be plugged up. From your picture, i can tell that you don't have the idle thing.
Old Nov 20, 2002 | 04:07 PM
-Whitey-'s Avatar
that isnt a 95 gsr t/b or a 92+ b16 t/b because the IACV(or what ever its called) isnt on it
Old Nov 20, 2002 | 08:15 PM
JHill's Avatar
Default Re: Throttle Body Help (B16A EH2)
That pic is a CRX Si throttle body, and the block off plate is not needed on that one. You can bypass the coolant just like your pic though, I just use a single long piece of hose and toss the two short ones.
The block off plate is for the FITV type throttle bodies.
Old Nov 20, 2002 | 08:40 PM
Xsi's Avatar
Xsi
Default Re: Throttle Body Help (JHill)
Thanks guys. I'm not sure what my new TB is off but it has the place for the FITV so it needs the plate, I was just wondering what to do with the coolant.
mien_civic715
31
May 16, 2021 05:33 AM
hkrichard
Apr 27, 2008 06:03 PM
bootlegtrader
Feb 5, 2006 09:04 AM
luc_cairo
May 2, 2002 06:33 PM
