Throttle Body adjustment screw?
Old Nov 10, 2002 | 07:02 AM
slvrcivic97's Avatar
Default Throttle Body adjustment screw?
Sorry if this is a stupid question. But I need to make sure. What is the best position to have the throttle body adjustment screw in?It has been previously adjusted before i got my car. Just wondering if I should have it turned all the way to the left or all the way to the right or right in the middle. Thanks. (Oh yeah, it is on a 97 civic coupe)Thanks.
Old Nov 10, 2002 | 08:01 AM
Chiovnidca's Avatar
Default Re: Throttle Body adjustment screw? (slvrcivic97)
Do you mean the idle air bleed screw or the throttle stop screw?
Old Nov 10, 2002 | 08:02 AM
Default Re: Throttle Body adjustment screw? (Chiovnidca)
The screw facing upwards on the tb which is a slotted screw with a hole in the middle.
Old Nov 10, 2002 | 08:18 AM
Chiovnidca's Avatar
If it has a jam nut, it's the throttle stop screw. It should be adjusted so there isn't any clearance between it and the throttle arm. It should also let the throttle plate close all the way.
Old Nov 10, 2002 | 08:26 AM
It is the screw towards the back of the tb. When you turn it to the right all the way, it seems as if the engine could shut down. Also, when I adjust it, where is the IAC sensor and evap sensor that I need to unplug?It is on a 97 civic. Because the procedures I have to fix the idling problem besides cleaning the IAC is : warm car to idle till radiator fan comes on. Disconnect the IAC and EVAP sensors. Adjust idle to 500 frpms then shut off. Reset ecu fuse for at lease 10 seconds and plug back in both plugs and start car. Just need to kind of know where the IAC and EVAP sensors are located. Thanks.
Old Nov 10, 2002 | 08:57 AM
Chiovnidca's Avatar
What engine do you have? d16y5, d16y7, d16y8 or another?
Old Nov 10, 2002 | 09:16 AM
d16y7
Old Nov 10, 2002 | 09:34 AM
Chiovnidca's Avatar
d16y7
I don't have to mess with them very often. That's the idle speed screw. To ajust the idle the engine should be at normal operating temperature. All electrical loads should be off. Do not disconect the IAC valve. Adj to 750+-50 RPM.
Old Nov 10, 2002 | 09:38 AM
Should I reset the ECU afterwards then. Thanks.
Old Nov 10, 2002 | 09:41 AM
Chiovnidca's Avatar
No
muddmonky
Dec 22, 2012 05:36 PM
rsspider
Feb 5, 2009 02:41 PM
95_red_dc
Sep 11, 2006 09:47 PM
bootlegtrader
Feb 5, 2006 09:04 AM
